September 21, 2026, 03:50:10 PM
| |-+  Down to Business (Moderator: Admin)
| | |-+  131 parts
Pages: 1 ... 20 21 [22] 23 24 ... 45 Go Down Print
Author Topic: 131 parts  (Read 1247578 times)
« Reply #315 on: June 28, 2010, 09:35:53 PM »
Yagmur you have an email, I don't know if it arrived or not.
Yagmur
« Reply #316 on: June 29, 2010, 06:55:56 AM »
I received it,thanks.
« Reply #317 on: July 07, 2010, 11:35:23 PM »
Yagmur,
Do you have a complete steering gear ( manual - No power assist)  assembly number 41201 including the steering column shaft  (as shown on the attached pictures)?
Any change for the mounting brackets ( 4323098 and 4307112) and rubbers (4323099 and 4323097)?
This is for petrol (not diesel)
M
« Last Edit: July 07, 2010, 11:42:24 PM by miro-1980 » Logged
« Reply #318 on: July 09, 2010, 07:19:47 PM »
hy Yagmur!
i'll be needing parts that go underneath wiper panel if you have those? wiper panel is ok so i don't need it.
please look into it and PM me the prices
« Reply #319 on: July 09, 2010, 09:07:56 PM »
Thanks for posting those pics djape because thats what ALL 131s are like under there & your car aint that bad i have seen far worse, Yagmur has all the parts you need to make your 131 new again i got all those parts off him! best of luck & keep the pics coming, Sid.
Yagmur
« Reply #320 on: July 09, 2010, 09:09:26 PM »
Hi Djape,
I have all these parts but to be sure exactly I will have to check them tomorrow at my shop and pm you with prices.
jack1
« Reply #321 on: July 09, 2010, 09:18:41 PM »
hi yagmur,,do  you  have  a  drivers  door  for  the  131 and if so  what  cost to get to the uk please  or  do  you  do  repair sections for the bottom  of  the door??
1996  850r (sleeper)
Yagmur
« Reply #322 on: July 10, 2010, 06:28:50 AM »
Hi Jack1,
4 door or 2 door
jack1
« Reply #323 on: July 10, 2010, 07:52:50 AM »
Hi Jack1,
4 door or 2 door
   sorry about that its a 4 door
1996  850r (sleeper)
jack1
« Reply #324 on: July 10, 2010, 09:00:31 AM »
i need a right hand more so than a left
1996  850r (sleeper)
Yagmur
« Reply #325 on: July 10, 2010, 09:02:55 AM »
I have 4 doors parts,many doors but not any left side at the moment.
I am going to try to supply one for you.
But what do you mean as driver's side???As our cars are lhd,!!!!!no left side,but many rhd.
jack1
« Reply #326 on: July 10, 2010, 09:05:37 AM »
right hand drive   drivers door
1996  850r (sleeper)
Yagmur
« Reply #327 on: July 10, 2010, 09:09:27 AM »
need your email adress
« Reply #328 on: July 16, 2010, 01:53:12 AM »
Yagmur,
As crazy as it may sound I am switching from power assisted to manual steering gear.
I need the cardan joints column with the rubbers and a damper but it has to have both sides with the same teeth kind.
See picture the top is for power assist and the bottom is what I need below .
« Reply #329 on: July 20, 2010, 11:51:24 PM »
Yagmur,
aside from the steering column , I also need  two of these this :
( I have to admit I have ordered the wrong part , but it seems to fit 124 spider).
« Last Edit: July 20, 2010, 11:53:10 PM by miro-1980 » Logged
Pages: 1 ... 20 21 [22] 23 24 ... 45 Go Up Print
