September 12, 2026, 12:49:55 PM
| | |-+  131 Sport / Racing Parts for Sale
Author Topic: 131 Sport / Racing Parts for Sale  (Read 4128 times)
hondacrf450
« on: December 04, 2016, 10:13:55 AM »
Selling a (new ?) rear boot spoiler, big vale head 4460623 (with valves and springs) and new (been fitted but removed before engine was run) high compression (1600) pistons and rings.
Also I still have a new Guy Croft 3A Camshaft for sale,Got the description below off the web (not GC's)
Guy Croft 3A grind performance camshaft This is a NEW cam, not reground, not welded, but ground by the top cam grinders in Europe from a NEW billet! 300 degree duration (at 16 thou� running clearance), 10.5mm true lift (10.9mm nominal lift) The 3A cam is very powerful street or rally camshaft - It is well suited for the intake side of 1800 and 2000 engines and can be used with stock, 2B or 3A exhaust cams - A pair of 3A cams with proper induction, exhaust and compression can deliver very streetable 165HP and will easily pull to 8000 rpm
The head has valves and springs assembled and the following numbers 4460623
« Last Edit: December 11, 2016, 04:38:50 PM by hondacrf450 » Logged
