September 14, 2026, 01:52:59 PM
| | |-+  Replica cd 66
Author Topic: Replica cd 66  (Read 9604 times)
ZFA16V
« on: August 06, 2017, 09:35:21 AM »
Hi
Would anyone know if a 15 x 7 with a 20mm offset fit a 131?(with standard panels)
Don't want to buy this set i'm looking at from the states if they don't fit.
I have 16 x 6.5 with a 20mm offset at the moment.
« Reply #1 on: August 06, 2017, 11:45:26 AM »
As this will be wider inside and outside. Don't forget to check the clearance against the springs and dampers, and depending on the tyre sizes,check the clearance against the back of the front wheel arch the bulkhead, and the bottom of the same but at the front edge.     Bulkhead is easily dressed back and dosnt change the pedle  space.
finnie
« Reply #2 on: August 06, 2017, 08:27:22 PM »
Try
willtheyfit.com 😉
ZFA16V
« Reply #3 on: August 08, 2017, 12:22:21 PM »
That's correct toad....wheel will be wider,in/out....but only by 6mmish.
Will check my clearances if i got room for this 6mm.
Finnie....that's for that info,as it helped.
they do suggest a 205/50/15,but i might fit at 195/50/15 maybe.
« Last Edit: August 08, 2017, 12:35:13 PM by ZFA16V » Logged
MrMaxi
« Reply #4 on: September 22, 2017, 12:09:44 PM »
Hey ZFA, did you end up getting these ?
