September 13, 2026, 02:30:34 PM
| | |-+  Alloy head welding wanted
Author Topic: Alloy head welding wanted  (Read 5869 times)
« on: February 25, 2018, 05:24:57 PM »
I’m looking for some one who can weld my 124AC Cylinderhead front waterway.
As some of you may know the 124AC head will not fit directly on a 132 block due to the front water way being too large on the cylinder head which impedes on the gasket seal of No:1 cylinder.
I have a rebuilt 124AC head.
Basic procedure would be to heat to 300 plus degrees, Tig weld (fill) wrap and let cool slowly followed by head skimming which I can get done elsewhere.
vode131
« Reply #1 on: February 28, 2018, 08:26:46 PM »
Make sure that there are no more holes that go under the firering. I have 125B000 head that is going to 84mm. block and we had to weld 4 holes and redrilled in right places. Two small holes at back of the head and one small hole in front and the big front waterway.
« Last Edit: February 28, 2018, 08:34:33 PM by vode131 » Logged
