October 15, 2026, 02:36:57 PM
| | |-+  Wanted - 131 gearbox with starter on right
Author Topic: Wanted - 131 gearbox with starter on right  (Read 8051 times)
cstorry
« on: August 07, 2023, 02:46:46 AM »
Searching for 131 bellhousing with starter on the right (passenger side).
I want to use a Lancia Delta balance shaft block with 131 5 speed gearbox. I have 131 gearbox marked 131 AB 1A 1005 but the starter is on the left (driver) side and the starter can not be mounted on the bellhouse since it hits the balance shaft cast into the block.
I believe that there are some 131 gearboxs that have a removable bellhouse I could use with my current gearbox that would mount the starter on the right side.
Can anyone confirm such gearbox exists and where I might buy this bellhouse? I don’t need the whole gearbox.
(I am in Canada and all 131/Brava gearbox’s here have the starter on the left).
Chuck
« Reply #1 on: August 09, 2023, 10:11:59 PM »
My automatic gearbox have a bellhousing for starter on both sides. Maybe you can find one close to you.
« Reply #2 on: February 23, 2024, 01:57:39 PM »
You need the gearbox from 1 series 1,3 or 1,6
