September 14, 2026, 01:35:38 PM
| | |-+  131 twin cam timing marks.
Pages: 1 2 [3] Go Down Print
Author Topic: 131 twin cam timing marks.  (Read 137632 times)
« Reply #30 on: September 18, 2008, 08:50:39 PM »
Hi Mark there was a 1980 sport up here that originally had the blue bumpers & arches but the owner painted them black, also there was a grey one with black seats & silver trim, mine had black trim & orange seats, there was a black one with black seats & black trim. if i get talking to the owners i will ask them for some pics  all seem to know i now have another sport!!!!!!!!!!!!!!!!!!
« Reply #31 on: September 25, 2008, 06:15:56 PM »
1.4 sohc have a plate behind the crank pulley coving the belt , can anyone scan the  other maual not the haynes the auto somthing one and timeing marks
SteveFX
« Reply #32 on: November 21, 2008, 02:01:10 AM »
Most of my Fiat TC mech experience was with 124's. I owned a few Coupes (Spiders were for sale: If I go dirty-side-up (not YET!) I want at least trivial tin overhead).
Bobdan's OHV timing mark pic was interesting. I never saw such under the sludge on a DOHC motor.
Early owners/repair manuals showed a "holding fixture" that locked all 3 sprockets together; at least on a 1438cc engine. US 1608, 1592, and 1756 engines (Lancias, too) seemed to use whatever aux sprocket the factory worker had at hand. Timing marks were NOT consistent.
I snow/mud bogged a 1438 coupe (no splash pan) and threw an accesory belt very near my rural home. I decided it was time for a timing belt too. I did not clean all of the mud out. Mud dropped onto a sprocket and jumped timing a tooth(18 degrees?). The aux shaft/fuel pump cam hit the #1 (#2, I forget?) rod cap and made more noise at idle than any engine running on less than 4 cylinders ever could. This mistake damaged the aux shaft oil seal and increased oil leakage. That would be considered a serious problem on any other make.
If not sure/if in doubt; rotate the crank to 40-45 degrees ATDC #1 cyl and rotate the aux shaft to find interference. When you do; turn the aux shaft 90 DEGREES either way.
I think by '78/'79; 1756 engines had a larger belt shroud cast into the front cover. All earlier US engines were no problen to bend the T-belt behind the crank pulley...
SteveFX
« Reply #33 on: December 09, 2008, 02:32:12 AM »
Sorry if I missed the edit function.
A US parts-peddler sold alloy cam sprockets for Fiats. A bit over-tightened T-belt wore 1/3 off of tooth height/width on alloy pulleys on a Lotus 907 in a Jensen-Healey in 700 mi. US 1756 Lancias had GRP cam pulleys. What's the wear story on them?
rally037
« Reply #34 on: June 28, 2023, 08:22:32 AM »
Hi
I know this thread is old, but a couple of things to add.
Firstly, you can slip the timing belt on without removing the crank pulley.  There's a way of sliding it in teeth outward and then turning it around the corner at the bottom.  Mine went in very easy (Engine is 131 volumetrico).
Secondly.... BUT... what I could do with is anyone who has timed the camshafts OTHER than with the standard wheels.  What are the settings?  thanks!
Pages: 1 2 [3] Go Up Print
