July 27, 2026, 03:59:28 PM
| | |-+  Help out needed
Author Topic: Help out needed  (Read 6970 times)
« on: April 04, 2008, 03:53:51 PM »
This question is not Fiat related.A friend of mine inLimerick(Kevs County)is buying a 2002 Toyota Yarus RHD.It now has Eire reg plates,but it was imported into Eire.The import reg plates on the car was MA50CWT.Does anyone know what country uses these plates.I don't think they are UK plates,but i could be wrong.The seller of the car does not know either.I would be grateful for any help on this, and when i get a result this thread can be removed as it is not Fiat related.Eugene
« Reply #1 on: April 04, 2008, 04:26:27 PM »
I think that the new style UK plates began around 2000/2001 using digits to indicate a rough indication of the year (second digit) and the part of the year (first digit). The first 2 letters are likely to be the geographical area the car was registered and the final 3 letters are randomly generated.
Back to the digits you will see cars registered with 01/51, 02/52, 03/53, etc.
A car registered as 01/01 could have been registered between Oct/Nov ish? 2000 and May/June ish 2001. A car registered as 51/01 is the next time indicator and is for the alternate 5 or 6 months of the year.
Using the above logic (which is probably inaccuarate in a few places I admit) this car should be a 2000/2001 model and not 2002 as it is advertised. You could do a vehicle query on the DVLA website and if the basic car details are confirmed...that is a little progress? Other clues would be UK dealers name on number plates, rear window, service stickers, service booklet stamps, etc. If the car has absolutely no history attached that should be a warning sign.? Shocked
« Reply #2 on: April 04, 2008, 07:51:05 PM »
Hi Guys,
Kev, you are almost correct mate, but if I may just put you straight on a few points. Wink
The registration number as shown is of the UK layout but, if it is absolutely correct certainly not a UK registration, as we have no '50' registrations. As Kev has correctly stated already, in the format (say) HX 04 EET, the HX state the region, the 04 indicates the year of registration and the EET would be unique to that particular vehicle.
The puzzle Eugene is the middle 50 of your stated number. Could this actually be 52 and not 50? The thing is that (again as stated by Kev) every 6 months the number changes from '0' something, like 02, to '5' something like 52. The whole '0' numbers run from 1st March to 31st August each year, with the '5' numbers running from 1st September to 28th (or 29th February).
Previously all UK cars had (from 1962) either letter suffix or (from 1983) a letter prefix, with the latter changing ever year on the 1st August. There is further complication in that to try to make the 51 reg (from 1st Sept 01) earlier year suffixes were changed every six months as well - thus a UK T reg (prefix) was from March 99 to end Aug 99, with V-reg from Sept 99 to Mar 00, and so on. The last UK suffix was a Y-reg, which ran from Mar 01 until end Aug 01. We didn't have an 01 reg Kev, the first in the new style was 51, as it was the end of 2001.
Another confusion is that (say) 53 covers the end of 2003 and the start of 2004 - so if Eugene's Yaris is indeed a 52 reg and not a 50 as stated, then it could conceivably be a 2003, but would certainly be at worst a late 2002.
It's all rather confusing, and most buyers try to purchase a new car on a '0-something' plate so that their mate's know that they have just brought a new car! Cheesy
We are currently on 08 reg Grin
Hope this helps Wink
