August 24, 2026, 09:48:17 AM
| | |-+  131 water pump..
Author Topic: 131 water pump..  (Read 16214 times)
« on: November 22, 2008, 01:21:53 PM »
After doing the timming belt on the 1.4? ?a couple of weeks ago , had to strip it all down again to do the water pump ,even less room to get the water heater pipe off the back of the pump than a twiny.
 and of course one off the long bolts snap off ,luckly at the head and not flush with the blok, god it was cold this morning ,ill put all back tommow Cry
jason
Gremlino
« Reply #1 on: November 22, 2008, 04:53:55 PM »
Jay,
You think it was cold today.....
I guess that water pump won't be getting done on Sunday...  Grin
Signature has gone Kaput!
« Reply #2 on: November 22, 2008, 09:20:00 PM »
That looks great graham, i bet its not to far off the true , finishing  may have to wait Cool
jay
« Reply #3 on: November 22, 2008, 10:13:11 PM »
Heres one i prepared earlier, much earlier approx 22 years ago lol.
« Reply #4 on: November 23, 2008, 12:37:57 PM »
in the good ole days when we had proper snow  Grin
 we only had half a dusting so got with it until my toes froze and then  battle onward till pump was back on and timing belt timed and test started all ok .. then the heavy dizzle started, so gave up, oh the luxury of a garage still none after 22 years working out side , next house a must  Roll Eyes
jay
Gremlino
« Reply #5 on: November 23, 2008, 12:47:35 PM »
Quote
Yep it was just a dusting this morning, not like 'old snow'.
Your right about the garage Jay, make sure its a double garage otherwise you end up having to push the car outside to work on it anyway  Angry  Cheesy
Glad your up and running with only a few bits'n'bobs to put back.
« Reply #6 on: December 03, 2008, 10:30:09 PM »
that bl......dy metal heater pipe is corroded slightly and is seping water  Cry i might try some cemical metal
 Angry
Gremlino
« Reply #7 on: December 03, 2008, 10:37:55 PM »
Quote
Sorry to hear that Jay,
Is it just around the end of the pipe where the hose attaches or is it right through the metal?
It could be cleaned off carefully if its only on the outer surface  Undecided
« Reply #8 on: December 03, 2008, 11:26:10 PM »
no . about an inch from the water pump right under the exhaust pipe, always had problems with these pipes on my twincams , ussally with the join with the pump
jason
« Reply #9 on: December 06, 2008, 09:47:22 PM »
 two small pin holes in the metal pipe ( propbely where i bent it down to get it of the end exhaust stud)
 so small bit of chemical metal over it seamed to have worked ... just got to get around to the clutch
 early next year Roll Eyes
Gremlino
« Reply #10 on: December 07, 2008, 01:17:14 PM »
Quote
Quote
Jay,
That pipe is 25 years old.....it was probably only meant to last for 5yrs.
It ain't done bad  Wink
« Reply #11 on: December 07, 2008, 01:21:08 PM »
get one made up from 316 stainless steel it will last forever.
