October 23, 2026, 09:35:21 PM
| | |-+  Ignition advice
Pages: 1 [2] 3 Go Down Print
Author Topic: Ignition advice  (Read 33881 times)
« Reply #15 on: November 01, 2009, 03:31:45 PM »
on a trailer & in boxes would be hard but when she is together you are on
« Reply #16 on: November 01, 2009, 03:39:59 PM »
Look forward to that race then.... but there will no spraying of champagne over the cars as we need to keep the rust away  Roll Eyes Roll Eyes Roll Eyes
« Reply #17 on: November 01, 2009, 03:41:24 PM »
Ok Dave champers for the bheil only
« Reply #18 on: November 01, 2009, 03:57:26 PM »
Sounds good to me that
« Reply #19 on: November 01, 2009, 03:59:39 PM »
Even points are good but it is setting them that people have trouble with
There's no magic to setting up points and a points system can work well. But points will need regular adjustment to work at their best. They are also limited to the amount of current they can 'sink' therefore limited to the strength of the spark they will produce and as they get pitted the situation gets worse. They are also limited to how fast you can open and close so about 8000 RPM on a four cylinder engine is their limit. Once you have more than 4 cylinders things get worse and manufacturers had to use twin point setups to get them to work reliably at higher RPMs.   But a well set up points system will produce sufficient spark to run a twin cam just as well as the 131 Sport electronic system but the points will need to be replaced and adjusted many times before the 131 Sport's magnetic pickup will need to be replaced.
« Reply #20 on: November 01, 2009, 04:06:53 PM »
Fitting points is part of a cars maintenance and even when they do give trouble you can generally engineer them to get going again but with the pickup or module in Electronic you best hope you have good reception  Roll Eyes but I do have an older Fiat that had a factory upgrade to electronic to let it rev to 10500rpm as the points were limited to 8500 rpm but how often would you drive to these limits.... but as they say keep it simple and less can go wrong  Grin Grin Grin
« Reply #21 on: November 01, 2009, 04:11:41 PM »
I see dave,that you are thinking along the LADA lines"keep it simple and less can go wrong" Roll Eyes Grin Grin Grin Grin Grin.I agree Grin Wink.Eugene
« Reply #22 on: November 01, 2009, 04:14:08 PM »
Eugene dont be agreeing with me or they might all think we are friends  Grin Grin Grin but if they had put points on the 999cc uno they would have given no trouble at all....
« Reply #23 on: November 01, 2009, 04:45:00 PM »
"friends will be friends"
« Reply #24 on: November 01, 2009, 05:35:55 PM »
Ah good one Sid but it just feels wrong with Eugene agreeing with me or me agreeing with him  Grin Grin Grin Grin Grin Grin
« Reply #25 on: November 04, 2009, 08:43:45 AM »
Get the 131 down here and we give it a seeing to but 400cc less and only 3bhp less  Shocked Shocked just remember it is the original of the sports species....
You can plow a paddock with the torque of a 2 litre but a 1.6 wouldn't pull a sailor off your sister!
« Reply #26 on: November 04, 2009, 09:24:07 AM »
thats great cant wait for the red fellas reply  Grin Grin Grin Grin Grin
« Reply #27 on: November 04, 2009, 06:11:08 PM »
Well at least Tas has a sense of humour and as for the sailor poor bastard wouldnt wish that on my worse enemy but all I know is the 1600 is a fast little bastard that still gives civics a seeing to  Grin Grin Grin but I wont let off the right pedal  Roll Eyes Roll Eyes Roll Eyes
« Reply #28 on: November 04, 2009, 06:14:10 PM »
civics?? they are girlie cars
« Reply #29 on: November 04, 2009, 07:17:01 PM »
Your right Sid they are for girls not like yorkie bars
Pages: 1 [2] 3 Go Up Print
