August 29, 2026, 09:44:34 PM
| | |-+  131 air filter
Author Topic: 131 air filter  (Read 11604 times)
« on: November 02, 2009, 09:48:07 PM »
Right my first of many to come questtions guys.I have a piper cross air filter on a webber carb on a 1980  131 2000cc tc mirafiori sport engine it currently has a pipercross pl200 air filter which is degrading.So i contacted Pipercross today and was told that the pl200 range was discontinued a number of years ago the guy recomended their px300 range witha universal base plate but i cant get a code or part number of the carb to make sure i order the right one .It is a single weber and has no visable part numbers.PLEASE HELP
« Reply #1 on: November 02, 2009, 09:52:12 PM »
If it is the standard 131 weber carb it should have the model number on the side of the carb bottom mounting near the base. It is stamped quite small so might be difficult to see with the carb fitted. Personally I would fit a K&N filter to it if I were you. From memory 34 ADF rings a bell but I'm not sure if this is indeed the correct carb.
I'm sure someone else on here will know for sure.
« Reply #2 on: November 02, 2009, 10:16:05 PM »
OK. THANKS I did think the K&N would be better but thought i could just get a direct replacment for the piper cross. The foam inside the pipercross was falling apart big time so that put me off. If i get the number on the bottom of the carb then i assume i can then order a universal k&n base plate and filter element.
REGARDS.....
« Reply #3 on: November 02, 2009, 10:26:04 PM »
K&N did do a filter for the 131 carb as I had one fitted to mine (before fitting twin 40 Dellortos).
Their listing is usually pretty reliable. See if you can find a on line seller and check out their catalogue.
« Reply #4 on: November 02, 2009, 10:28:52 PM »
Such as this....
http://www.performance-filters.co.uk/p1511088.htm
« Reply #5 on: November 02, 2009, 10:42:00 PM »
 Thanks for the info man.............. I will discuss the twin 40 option with you through te week.
Thanks.
