October 23, 2026, 01:52:30 PM
| | |-+  Fuel Injected Twin Cam
Author Topic: Fuel Injected Twin Cam  (Read 26830 times)
pavlos
« Reply #15 on: November 06, 2009, 06:10:28 PM »
i didnt undestud theredx19 the two enginens are the same 1.6 tc 131 and 1.6 hf turbo carb the diference are at the compecion 9/1   8/1 and the pistons      131 had high comp  lancias was flat top   inlet outlet   same dimensions  i just want to know if it  will work well  if i change pistons head gasket and put on 131 block lancias inlet and outlet with the intercooler
« Reply #16 on: November 06, 2009, 06:19:07 PM »
The turbo valves are sodium filled to take the heat but the crank pins are different as far as I remember but you are better fitting the whole engine as the oil feed for the turbo is not in the 131 block.
« Reply #17 on: November 07, 2009, 10:44:37 PM »
Hi Kev.Whats your hurry in buying a 132 Roll Eyes.Take your time and the write car will turn up with the write price.Maybe a one thats better than the red one will turn up for less money Roll Eyes.Just my opinion
