September 14, 2026, 05:59:52 PM
| | |-+  Clutch cable 131 s 75-84
Author Topic: Clutch cable 131 s 75-84  (Read 19692 times)
« on: November 05, 2009, 10:27:27 PM »
SORRY for all the questions guys.
Im starting to build up a spares collection.
Will a clutch cable for a 131 s 75-84 be ok for my sport ?.
I assume the 131 s means special not sport.?.
Ordering and finding  parts when not an expert can be awkward sometimes as you have 1.3 1.6 2.0 2.0 diesel OHV DOHC etc.
Thanks.
MacL....
« Reply #1 on: November 08, 2009, 11:17:05 AM »
Re your question on clutch cables, all the twin cam versions (rhd) I have seen (inc sport) have had a long cable which comes out of bulkhead attaches to the front crossmember (below radiator) via clips and then to gearbox and the other versions (ie pushrod engines) use a short cable which goes across the top of the engine. most of the clutch cables I have seen on ebay etc are the short version for the push rod engines.
« Last Edit: November 08, 2009, 11:22:07 AM by david » Logged
« Reply #2 on: November 08, 2009, 01:53:55 PM »
David the one i bought on ebay is 1630mm long tip to tip would you say this the right one for the twin cam.
« Reply #3 on: November 08, 2009, 03:32:00 PM »
I would guess yes but as usual although I have one somewhere I can not find it to check for sure! I assume you still have one on the car? If so I would compare the two to check it out.
« Reply #4 on: November 08, 2009, 04:58:48 PM »
just measured one for you and its 1935mm inner cable end to end and the outer cable is 1730mm end to end, hope this helps
« Reply #5 on: November 08, 2009, 05:36:54 PM »
not sure about this but as far as i remember there are cables with a ball on the clutch end & ones with a bolt screw for adjustment Huh Huh Huh
« Reply #6 on: November 08, 2009, 05:48:28 PM »
Only one I have seen on 131s Nick is a plastic ball end with 17mm head and a 10mm lock nut but thats on mk2 & mk3 cant comment on mk1 versions
« Reply #7 on: November 08, 2009, 07:00:22 PM »
Dont want to go on about this one but would like to know what the S in 131 S stands for when ordering or looking for parts is it special or sport ?.
 It must be wrong one i have if Daves clutch cable measures 1935mm and this one is 1630mm.
« Reply #8 on: November 08, 2009, 07:19:38 PM »
The S stands for special which was a series 1 model. Looking at the photo you posted I don't think it will fit a sport as the clutch end of the cable is the wrong design.
As far as I know all the cables for series 2 and 3 cars with the five speed box had the threaded end described earlier.
Simon and a few others have series 1 131s on here. Sell it to one of them as a spare Grin
« Reply #9 on: November 08, 2009, 08:52:33 PM »
That cable in the picture definately is not for a sport or any mk2 or mk3 but the pedal end is the same so it must be mk1 ?
« Last Edit: November 08, 2009, 09:00:41 PM by david » Logged
« Reply #10 on: November 08, 2009, 10:40:22 PM »
Thats that issue sorted then wrong cable.
Thanks for all the info .
Yagmur
« Reply #11 on: November 09, 2009, 08:55:09 PM »
whay don't you ask me about clucth cable,10Euro,may be same.
« Reply #12 on: December 15, 2009, 11:40:37 PM »
Got the correct clutch cable. Brand- Cavoflex Italy. 1935mm long as stated by Dave.
and with the threaded end.
Paid ?6 on net.
« Reply #13 on: December 16, 2009, 01:28:15 AM »
Any one want the series 1 cable i have spare??
If so Send me your details will sell for ebay price i paid ?5.55 plus post .
Other wise i will list it on ebay.
Thanks..
