November 05, 2025, 11:43:09 AM
| | |-+  Fiat 131 Abarth Replika at AutoScout24
Author Topic: Fiat 131 Abarth Replika at AutoScout24  (Read 4552 times)
« on: February 20, 2010, 01:18:38 PM »
Hello,
for sale in switzerland for 49000 CHF = 33000 EURO = 29000 GBP
http://www.autoscout24.ch/AS24Web/Detail.aspx?from=list&wl=1&lng=ger&id=6301488&qs=from%3dDefault%26zipcountry%3dCH%26make%3d28%26modellike%3d131%26cur%3dCHF%26total%3d3%26eftotal%3d3&page=1&row=2
Look's nice,  OK SID such another 131 Racing in heaven  Cry
Enzo Wink
« Reply #1 on: February 20, 2010, 02:55:23 PM »
Enzo correct gone to heaven Grin Grin
that looks nice & love the wheels, its a proper job & not butchered like some of the abartized things.
« Reply #2 on: February 21, 2010, 02:36:13 AM »
Very nice  !
Few  comments :
- Mk 2 body (not my favorite by acceptable) ;
- good alitalia markings
- wrong Abarths decals ;
- I do not like the wheels ;
- wrong front halogen light ;
- wrong mirrors
- wide tarmac arches (nice)
- (these arches require Grp. 4 dash !)
- rear panel - looks damaged
- no sump guard plate
- (most likely) yellow sports Koni's- too soft !
- bolted not welded cage
- 4 points belts
- oil cooler good but too small
"Zylinderkopf ist 8 Ventil vom 1600 Spider,
Kan?le erweitert und poliert, alle Ventile neu
Nockenwellen vom 124 Abarth
2 Doppelvergaser Weber IDF 40"
I do not believe in 160 bhp with this setup, especially with Weber 40 IDF's, 42/36 cams (124 spider 1592cc head) and no adjustable camshaft wheels , but compression may be quite high (depending on pistons used - no data) No word on shaft and rods?
33000 EURO price tag is not cheap but if the body is as nice as it looks in reality , engine, gearbox and diff (with LSD !) are in good condition the car is probably worth the money.
cinqabarth
« Reply #3 on: February 22, 2010, 11:59:51 AM »
Just thought i would put it in english Wink
Based on Fiat 131 Racing Year 1979 Carrosserie and security after the Group 4 FIA regulations of 1976 set out in Annex J and K Motor 1995 ccm ca 160 hp block is original 8 valve cylinder head is cooler by the 1600 Spider, channels expanded and polished, all valves from the camshaft new 124 Abarth 2 Dual Weber IDF carburetors 40 from the exhaust manifold and muffler Semi-custom (registered in the vehicle license) from the original transmission of 131 Racing Shifter Abarth rear is the Originalstarrachse with 70% lock brakes front and larger ventilated brake discs hydaulisch suspension struts front of the Mitsubishi Lancer evo, Semi-custom shock absorbers and rear springs Koni yellow front wheel 7 x 15 with 225/50 rear wheel 9 x 15 with 245/40 Tripmaster is Retrotrip with 2 counters, speedometer cable with sensor is newly included all inc Homologationspapiere Supplements for a roll cage, wheels, carburetors, suspension struts Tripmaster is Retrotrip with 2 counters, speedometer cable with sensor i
?30,000
Its alot of money for what it is. To much if you ask me
x2HS Chevettes,Hillman avenger GT,Uno Turbo MK1 Antiskid,Commer pb van,Commer pb camper,Commer pb pick,Lancia Delta Itergrale,Triumph Stag,Transit150 mk5,Transit mk5Hallmark,Transit mk2 recovery truck
