October 23, 2026, 04:52:18 PM
| | |-+  sparkplugs
Author Topic: sparkplugs  (Read 17005 times)
124 man
« on: August 03, 2010, 09:57:48 PM »
What are the best plugs for the twincam with unleaded petrol , n9y ?
Keeper of 124s 125 &  132
« Reply #1 on: August 04, 2010, 11:38:16 AM »
NGK bpr6es
« Reply #2 on: August 04, 2010, 01:29:33 PM »
I don't think the petrol has much to do with it but N9Y are the wrong ones; they are meant for the OHV engines and later single cams.
I believe the correct spark plugs for the twincams are:
Champion: N6Y (better N6YC best N6YCC). Not easy to find these days so some people suggest changing to N7YC or N7YCC.
NGK: BP8ES which are very difficult to get hold of. BP6ES (or BPR6ES, the 'R' is for 'Resistor' which acts as a suppressor for radio interference) are equivalent to N9Y so I'd say not the right ones for a Twin cam. Having said that, I have seen them listed as suitable for Fiat Twin cams. By the way, if you have good quality suppressed HT leads then it's better to go for non-suppressed spark plugs (without "R" in the name)
Bosh: W200T30 These are meant to be equivalent to Champion N6Y but I found them to be useless in my 2000 Twin cam lasting only about 3000 miles so I'd strongly recommend not going for these. But I am now using Bosch Super-4 W56 spark plugs in my Fiat with good results. W56 plugs are also getting hard to find these days but the suppressed equivalent (WR56) are still readily available.
« Reply #3 on: August 04, 2010, 03:01:00 PM »
ngk bpr6es for the 2000 twim cam as they always ran well on these.
« Reply #4 on: August 04, 2010, 05:10:00 PM »
Are these any good for the 1600 twin cam also?
« Reply #5 on: August 04, 2010, 05:43:44 PM »
Hi Chaps,
      NGK BPR6ES were the standard Plugs for both engines, the Compressions are the same. I didn't  know anyone still used Champion Plugs after they had such a bad name for braking down.
  So, BPR6ES for normal/slow driving
        BPR7EV for more spirited driving   140/150ish
        BPR8?? for Moded engines over this power.
                   So I Think
                          Roger............... Grin
« Reply #6 on: August 08, 2010, 01:56:39 AM »
Roger , I think the same...
For really highly tuned engines 160-190 bhp I would recommend a NGK "9"
Normal driving  ONLY:  NGK BPR6ES
124 man
« Reply #7 on: August 08, 2010, 05:03:50 PM »
How about denso w20 epu ?
« Reply #8 on: August 08, 2010, 07:35:59 PM »
I thought Denso was ether part of NGK or of a similar quality. Any body know different?
         Roger...........
MF 131
« Reply #9 on: August 31, 2010, 03:34:14 AM »
Hi Mike. Photos of carbs. Cheers Gary
124 man
« Reply #10 on: August 31, 2010, 08:08:50 AM »
Thanks for that gary , when you delivering them  Grin
MF 131
« Reply #11 on: September 02, 2010, 03:23:58 AM »
Would have to win lotto or sell MF 131. All donations accepted. GO THE IRISH just behind the ALL BLACKS
