October 16, 2026, 02:16:50 PM
| | |-+  34 ADF
Author Topic: 34 ADF  (Read 16300 times)
« on: September 12, 2010, 09:33:09 PM »
Does any one have a new bottom gasket/rubber for the adf 34 Weber.
It fits between the carb & the manifold.
Or does anyone know where i can get one ??
Thanks.
ADIGA131
« Reply #1 on: September 12, 2010, 11:55:11 PM »
i think u may see this, if its would help  Wink
http://www.di-michele.de/html/_vergaser_kit_s_weber.html
*{ADiGA}*131
« Reply #2 on: September 13, 2010, 11:55:33 AM »
Hello.
Thanks this helps !
where is this seller in the world ??
ADIGA131
« Reply #3 on: September 13, 2010, 04:02:25 PM »
Germany , everything can be shipped..
*{ADiGA}*131
« Reply #4 on: September 13, 2010, 04:51:02 PM »
106,  do you mean the spacer ?
« Reply #5 on: September 13, 2010, 05:32:03 PM »
Hello David,
I need the the bottom gasket it is the last rubber seal between the base of the carb and the manifold.
It is about 3/4 inch thick.
« Reply #6 on: September 13, 2010, 05:35:39 PM »
Maybe it is called a spacer i am not sure of the correct name for it,David.
Thanks.
« Reply #7 on: September 13, 2010, 07:25:14 PM »
Ebay seller in germany is good or you could try Matt at Eurocarb (In the UK)
« Reply #8 on: September 13, 2010, 09:37:52 PM »
I've got a couple lying around that I have no use for.
« Reply #9 on: September 17, 2010, 02:09:11 PM »
This one for sale on ebay USA for $16 (?10.22p), I think this is the part you want ?
* !BwP19lwB2k~$(KGrHqMOKn!EvyFr)j6dBMIEKRQ7IQ~~_35.jpg (8.82 KB, 300x225 - viewed 1420 times.)
« Last Edit: September 17, 2010, 02:12:52 PM by david » Logged
« Reply #10 on: September 17, 2010, 11:18:46 PM »
Hello David.
Just got to your post but cant find it do you have a link ?
Thanks 106
« Reply #11 on: September 18, 2010, 07:17:35 AM »
106,  I can't post links !  I have tried but it won't work ! .  If you go to Ebay USA and put in "fiat 131" on the seach its on the first page and it has  1 day 22 hours left to run and the item no is  330445277956
sam22
« Reply #12 on: September 18, 2010, 11:13:29 AM »
hi 106 go to ebay and type in the item number in the search bar and that will find it for you.
« Reply #13 on: September 18, 2010, 10:18:16 PM »
Thank you both.
Sorted !!
