October 23, 2026, 07:38:06 PM
| | |-+  Which Fiat-Lancia-Alfa cars had rear disk brakes with 240 + disks ?
Author Topic: Which Fiat-Lancia-Alfa cars had rear disk brakes with 240 + disks ?  (Read 6846 times)
« on: February 14, 2011, 11:12:39 PM »
Which Fiat-Lancia-Alfa family of cars had rear disk brakes with disks larger than 227 mm?
Guys.
Need your help.
I have to figure out what to use o my rear.
The front will be RS 911 two 48 mm piston calipers with 250-285 vented disk.
I need to put  enough braking power on the back to be able to have nominal as close to 50/50 split as possible (adjusted up and down by Tilton adjuster).
My rear hub mounting holes have a distance of 145 mm (center to center). or ( another hub -76 mm )
I currently have rear calipers from 125p with 227 disk and look for something with two bigger pistons and 240 plus disks.  Any ideas ?
Does anybody know what we could use ?  Fiat (Argenta ,130 ?) Lancia (Delta, Thema)  Alfa (154 , 164) .....  ?
« Last Edit: February 15, 2011, 02:23:55 AM by miro-1980 » Logged
« Reply #1 on: February 15, 2011, 11:01:30 AM »
Hi Miro,
i have send you e-mail!
and this are also to mount they are from Lancia Delta III  and with 251mm diameter and 4x98 PCD.
Enzo  Wink
