October 24, 2026, 10:07:37 PM
| | |-+  Which is best?
Author Topic: Which is best?  (Read 24039 times)
« Reply #15 on: October 24, 2012, 12:49:30 PM »
It's no problem if the engine runs a bit more over 93 degrees. Fiat engines are strong. One should more worry about the engine not getting warm enough. That really kills the engine. The right thermostat is essential.
« Reply #16 on: October 31, 2012, 11:01:47 PM »
I have used my previous engine for sports for several seasons.( It was  pretty much a good standard engine with twin soled 34's , standard valves, standard rings, cast rods, con rods - standard everything.  When I pushed really hard with high outside temperature (30 deg plus) my oil temperature would top 130 deg centigrade and the coolant got to 110 but the engine survived with no problems. So the engines are indeed very, very  strong. They often run at close to 100 degrees ( 93/96/98) and no visible problems.
The standard engine setup, especially 1600 (single 34 carb) is not exactly a 2.0 with twin 44 's and "sharp" camshafts. Also a car made for general distribution and general standard (non competition use) probably runs with somewhat better efficiency at 93 degs and less fuel consumption, too.
However, I strongly believe keeping a competition engine at full speed and 6-8 K RPM with 85 temp is far better than at 93 degs.
Changing the fan switch and installing the in-head thermostat did the trick for my 131.
Similarly, by using use of proper rated switch and thermostat combination I have been able to keep my 124 2.0 fi also close to 85 degrees at all times.
Finally the car oil temp stays reasonable level no matter how hard I drive it  and no matter how hot  is the outside temp.
The fact is that for winter driving ( wich \i do not fo=do in my fiats at all) I would keep the engine temperatrure slightly higher probably 90 deg max.
Re too low temperature kills the engine - Very true. In fact starting a cold engine causes the greatest damage (priming it with oil pressure from oil accumulator does help a lot). But wear and tear due to cold engine can be very dangerous, as the lubrication/oil pressure and its distribution throughout the oil channels is under low temperature grossly insufficient.
However, with extremely high temperature oil lubrication (its viscosity) degrades drastically killing main shaft bearings and camshaft bearings much quicker and can lead to a engine blow out. Using competition oil can reduce both.  Provided your oil pressure is sufficiently high and oil matches the driving conditions (outside  temperature ) keeping 85 degrees lubricates the engine properly without causing thermal damage to main engine bearings.
The bottom line:  as long as your engine works well and its temperature does not exceed 90 deg under any driving conditions and your style of driving - you should be fine. If you use the car for competitive driving I strongly recommend 85 max , oil accumulator and oil changed according to expected driving conditions.
I use Motul 20-60 for the summer and 15W-50 for cold weather ( non freezing winter driving).
M
« Last Edit: October 31, 2012, 11:49:59 PM by miro-1980 » Logged
alan.acs
« Reply #17 on: November 01, 2012, 11:39:21 AM »
The grade of oil to use depends on the seals fitted and the bearing clerances.
Most early twincam seals leaked oil if you used fully syn oil.
But the later types are made of a different grade of material and are ok for fully syn oil
124AC
« Reply #18 on: November 20, 2012, 11:21:26 PM »
If you study the range of oil filters fitted to the twin cam there are many options to choose.
The 131 has a lot of space under the bonnet and they fitted a 'fat' oil filter.  The spec is identical to those used on the Ford (sorry) Pinto engine in the Escort/Cortina/Granada/Taunus etc.  Make sure you get the one with the valve.  look down the hole and you will see the valve at the base.  This keeps the oil galleries primed and therefore helps the engine achieve pressure sooner on startup.
If you need a smaller filter as per your picture, choose the one fitted to the Lancia Integrale 8V or 16V.  If it can live behind the radiator, under the exhaust manifold, and surrounded by the turbo and exhaust, while filtering an engine producing 185BHP+ I think it will be OK for your application!
If you are really concerned about oil pressure and startup damage fit a pressure switch to the filter housing and wire it into a relay in the ignition circuit.  The engine can't fire until the oil pressure builds, and if the oil pressure fails the ignition is cut automatically.
Finally Semi Synthetic is probably best for your engine.  The twin cam loves good oil, and the film strength for semi synthetic is so much higher that normal mineral oil that it provides better protection in all conditions.
Duncan
keith m 131
« Reply #19 on: November 21, 2012, 11:39:35 AM »
Thanks Duncan for the info, very informative. I will try the Integrale filter as suggested. I will let you know how I get on.
Does the valve look like a spring similar diameter to the treaded hole.
keith
« Last Edit: November 21, 2012, 01:37:00 PM by keith m 131 » Logged
124AC
« Reply #20 on: November 21, 2012, 11:10:20 PM »
Hi Keith
If you look down inside the filter you should see a spring-loaded valve at the bottom of the hole.
Many years ago I ran a motor factors and we were often called upon to supply parts for cars not listed in the general catalogues.  Suppliers such as Girling, Champion, Bosch etc are very good at providing the trade with the proper technical specifications for their parts.  This allowed us to find a suitable oil filter for a car based upon the quoted features.
You would be surprised how many 'supercar' parts came from everyday mundane vehicles!
The Minor looks fantastic by the way.  Always good to see one running, and the twin cam adds to the appeal.
Where are you based?  I travel a lot in the UK and I'd like to see the beast.
Duncan
keith m 131
« Reply #21 on: November 22, 2012, 02:16:27 PM »
Hi Duncan,
I am based near Boston in Lincolnshire. The car is playing up a bit at the mo, if you read my other 2 threads you will understand why, hopefully it will be sorted soon and running to its full potential.
keith
« Reply #22 on: November 22, 2012, 07:40:03 PM »
I used to use the 'slick 50 ' metal coating supliment ..
