October 18, 2026, 09:16:52 PM
| | |-+  131 1975 steering rack wanted
Author Topic: 131 1975 steering rack wanted  (Read 17079 times)
Japk577
« on: December 18, 2012, 06:12:34 PM »
Hi has any one got a good rack in south west hope fully if not any suggestions on repaire
« Reply #1 on: December 18, 2012, 07:55:42 PM »
What is the fault with the rack exactly? Some bits can be replaced/reconditioned.
Japk577
« Reply #2 on: December 18, 2012, 08:15:48 PM »
Failed mot with play clunk clunk wen rocking wheeles side to side
« Reply #3 on: December 18, 2012, 08:33:45 PM »
You need to try to identify where the wear is. If it is in the track rods these can probably be replaced. If it is in the rack or pinion then a new steering rack is probably the best option.
Japk577
« Reply #4 on: December 18, 2012, 11:37:29 PM »
Ok il pop it out  ta
« Reply #5 on: December 19, 2012, 12:33:20 AM »
131 steering racks have an adjustment nut to set the pressure between the pinion and the rack and create some damping to the steering. If this is too loose there's a lot of freeplay and you get clunk clunk over rough ground or when moving the wheels.
« Reply #6 on: December 19, 2012, 08:13:53 AM »
There's also a replaceable bush in the tube, it supports the rack at the opposite end from the pinion.
Japk577
« Reply #7 on: December 19, 2012, 05:43:29 PM »
Ok thanks for advice it's not in track rods were can I get the bits on the end of the pinion ie the bushes
Yagmur
« Reply #8 on: December 19, 2012, 08:22:17 PM »
Hi all,
Why are you trying hard, just call me and I can send a brand new one...
Japk577
« Reply #9 on: December 19, 2012, 09:19:06 PM »
How much wats you're number
Yagmur
« Reply #10 on: December 19, 2012, 09:35:05 PM »
Hi,
I think you haven't  read my topic yet...
http://www.131mirafiori.com/smf/index.php?topic=81.0
www.rainspeed.com
 you can see the pics of the steering racks...
Japk577
« Reply #11 on: December 19, 2012, 10:10:05 PM »
Ok I see we're r u located turkey
Yagmur
« Reply #12 on: December 20, 2012, 06:20:58 AM »
yes
« Reply #13 on: December 20, 2012, 08:06:31 AM »
Yagmur, do you have new steering racks for RHD cars?
James, I thought you said your car was an S-reg? That makes it a 1977-78 car not 1975. Might have an impact on the type/design of rack fitted as FIAT sometimes modified parts.
Yagmur
« Reply #14 on: December 20, 2012, 10:13:15 AM »
Hi Simon,
No I have only lhd parts....
