August 29, 2026, 03:58:53 PM
| | |-+  Info Thermostat in Head ?
Author Topic: Info Thermostat in Head ?  (Read 11180 times)
« on: February 09, 2013, 03:42:45 PM »
Hi Smiley I am looking on any info regards running the thermostat in the head of a 131 2.0 twincam, I am thinking about doing this to my Panorama engine that I am getting rebuilt  Smiley any info as to what I have to do re plumbing & where to get the thermostat etc would be greatly appreciated Smiley
« Reply #1 on: February 09, 2013, 08:51:35 PM »
Have a search on the Guy Croft site as this subject is discussed there at length. My engine has the thermostat in the head. I believe the housing in the head needs to be enlarged slightly to take the thermostat. You must make sure your thermostat has a small hole in it to avoid air locks. The thermostat in my car is from a Ford Fiesta. According to people on Guy's website the best thermostat to use is a Unipart item. I can't remember the part number  Undecided. As far as plumbing goes, the radiator bottom hose connects directly into the water pump and the T-piece at the top, fed from the head, needs to have one end blocked so it simply connects to the radiator top hose. Ideally, instead of blocking off one end of the T-piece, it's better to have a curved connector from the head to the radiator as water flows better round curves than right angles. My engine has a custom made curved copper connector at the head connecting it to the radiator top hose.
« Reply #2 on: February 10, 2013, 12:00:11 PM »
Thanks for the info Smiley
« Reply #3 on: February 10, 2013, 09:55:46 PM »
Why bother going to the trouble. Fiat obviously thought moving the thermostat out of the head was a good idea. The engine has continuous full flow through head/block with an external thermostat, unlike the no flow or restricted flow through an in head thermostat.
« Reply #4 on: February 10, 2013, 10:48:12 PM »
The 131 it's for will be the way I want it to be and not the way Fiat  intended it to be Grin
« Reply #5 on: February 10, 2013, 10:49:19 PM »
I cant find anything on the Guy Croft site about this Sad Huh
« Reply #6 on: February 10, 2013, 10:57:29 PM »
Some time ago we had this dispute. I think there is something to say for both options. But Fiat invented one of the greatest engines. It has the thermostat next to the engine. And yes, for a reason. Even the race engines had their thermostat in the same place. There must be a reason.
cypriot
« Reply #7 on: February 26, 2013, 08:26:11 PM »
http://www.guy-croft.com/viewtopic.php?f=13&t=1832
Here is the link which there is discussion about thermostat location
WR Ltd Edition
Mods:
Gr.4 Tarmac BodyKit
124 Abarth cyl head
High Comp. Pistons
4-1 Header
H?rmann Intake Manifold
Weber 40 IDF Carbs
GC Spec FW
« Reply #8 on: February 26, 2013, 08:39:50 PM »
Thanks Smiley
