August 30, 2026, 01:56:31 AM
| | |-+  Fiat 131 2 Door window regulator
Author Topic: Fiat 131 2 Door window regulator  (Read 9186 times)
cypriot
« on: March 03, 2013, 07:43:05 AM »
Hello,
Does anyone have door illustration for Fiat 131 2 door ?
I found some info but probably it is for 4 door model
http://www.mirafiori.com/faq/images/celovsky/131-doors.jpg
I need to find out pulley locations etc.
I locally found 3-4 window regulator from Tofas but all of them has different wire length from the one.
Ali
WR Ltd Edition
Mods:
Gr.4 Tarmac BodyKit
124 Abarth cyl head
High Comp. Pistons
4-1 Header
H?rmann Intake Manifold
Weber 40 IDF Carbs
GC Spec FW
« Reply #1 on: March 03, 2013, 08:46:58 AM »
The picture you have there is for 4 door. The two door is a cable and will have a sticker on the back of the mechanism with  " 2P " on it .
« Last Edit: March 03, 2013, 08:57:19 AM by david » Logged
cypriot
« Reply #2 on: March 03, 2013, 09:05:02 AM »
Hi
Thank you for reply, do you know what is the wire length for 2 door window winder ?
Ali
WR Ltd Edition
Mods:
Gr.4 Tarmac BodyKit
124 Abarth cyl head
High Comp. Pistons
4-1 Header
Weber 40 IDF Carbs
GC Spec FW
« Reply #3 on: March 03, 2013, 09:33:44 AM »
I have some at my fathers and I may get up there today but the only length I will be able to give you is the length when the cable and mech are stretched with both hands.
The four door cars have a cable in the rear doors but as I recall this is shorter and has a "4P" sticker on it.
« Reply #4 on: March 03, 2013, 04:12:03 PM »
Right, If you hold the thin end of the mechanism in your right hand and the cable on your left thumb and take up the slack the total length is  37 inches or 940mm from cable end to mech end.
cypriot
« Reply #5 on: March 03, 2013, 04:34:32 PM »
Thank you for information David
WR Ltd Edition
Mods:
Gr.4 Tarmac BodyKit
124 Abarth cyl head
High Comp. Pistons
4-1 Header
Weber 40 IDF Carbs
GC Spec FW
