September 16, 2026, 08:42:35 PM
| | |-+  Repairs and upgrades to a 1585 TC
Pages: 1 [2] 3 Go Down Print
Author Topic: Repairs and upgrades to a 1585 TC  (Read 39461 times)
124CC
« Reply #15 on: December 18, 2013, 09:15:56 PM »
I 've got 2lt cams,  adjustable camgears,
twin 40 IDF's,
2lt exhaust manifold and
custom made exhaust system.
I will also install an electronic ignition soon as I find one  Grin
« Last Edit: December 18, 2013, 09:50:53 PM by 124CC » Logged
124CC
« Reply #16 on: December 25, 2013, 08:27:13 AM »
I came across a supposingly 105tc head from a friend.
The number on the casting is 5992169.
We measured the chamber volume and it is the same as the 5936188 head I already got. (Around 52-54 cc)
Is this head really a 105tc head? Any ideas?
« Reply #17 on: December 25, 2013, 10:56:19 AM »
Hi 5992169 is Regatta 100S head,
5992303 105/130 tc
4462603 late 105 tc
hope this helps Wink
« Reply #18 on: December 25, 2013, 11:21:14 AM »
You have a very useful database there Nick.... Smiley
« Reply #19 on: December 25, 2013, 12:19:24 PM »
5936188 is an Lancia Beta Volumex head, intersting it is with sodium cooled exhaust valves!
124CC
« Reply #20 on: December 25, 2013, 02:10:28 PM »
It is interesting but the delimma still remains.
Option 1. Volumex head with big valves and ports and 9,3 - 1 compression ratio or
Option 2. The standard head (no. 4371507) with polished ports and skimmed to the limit which produces around 10 - 1 compression ratio.
Huh
The engine will work with 2l cams and twin IDF 40's...
The car is used for historic racing events.
« Last Edit: December 25, 2013, 02:16:37 PM by 124CC » Logged
« Reply #21 on: December 26, 2013, 10:18:21 AM »
if you not sure?
here you can found some same questions:
www.guy-croft.com
this is very interesting:
http://www.turbo124.com/forum/viewtopic.php?f=10&t=7743
124CC
« Reply #22 on: December 27, 2013, 09:08:29 AM »
Read them both, very useful info. Thanks!
124CC
« Reply #23 on: December 30, 2013, 07:04:17 AM »
I decided to use the big valve ritmo 130tc head but then I found out that the 105tc/Regata 100s head I have, although it also has the big 43.5mm valves it has smaller ports than the 130tc.
The 130tc has 36mm ports and the 105tc has 32.
My engine is 1585cc so I was thinking maybe the 36mm ports are too big for this engine and it would be better if I use the 105tc head?
131 Lover
Fiat power No mercy !!!
« Reply #24 on: December 30, 2013, 09:11:14 AM »
Hi Stephen!
I would use the 100s head,you will get higher gas velocity and a higher comp with it and still have the same good flow as the 130 head, if you had used race cams I would just ported it as you can do anyway in the roof area and enjoy the raised port centerline!
Alf
These are my Fiats
2x 131 2-door 1600cl -81
124CC
« Reply #25 on: December 30, 2013, 04:14:44 PM »
Hello Alf.
Thank you for the reply.
I understand why the gas flow will be faster but why is the compression going to be higher?
I measured both heads and the volume of the chambers is the same!
131 Lover
« Reply #26 on: December 30, 2013, 05:48:52 PM »
No,if they both are untouched the 100s has a volume of 48cc and all 2l has 54cc so you will gain another 0,5 of comp give and take with the 100s head!
A happy new year to you and the rest!
Cheers Alf
These are my Fiats
124CC
« Reply #27 on: January 01, 2014, 10:16:47 AM »
So from everything that I have read, I have concluded to the following and please correct me if I am wrong.
- The 130tc head ports are way too big for my 1585 hence the mixture flow will be significantly slower.
- The 100s head provides very good flow characteristics from factory, especially for my 1585cc engine and gives
  higher compression ratio than the 130tc head.
- Unless I replace the 2l cams I have with racing ones, I do not need to port the head in the roof area unless I
  want to but I will not see much difference with my current setup.
- I can also lighten the valves by grinding off some of the material in the valve face to get better valve spring
  response.
Am I missing something ?
« Last Edit: January 01, 2014, 10:52:36 AM by 124CC » Logged
vode131
« Reply #28 on: January 01, 2014, 03:13:42 PM »
My opinion is that valve lightening is total waste of time. Stock springs are so stiff that it is not necessary with standard cams.
If you want to work with valves back cut them for better flow.
131rally
« Reply #29 on: January 01, 2014, 05:00:20 PM »
What is the difference between 2.0 and 1.6 cams? I would change the cams, your getting very slight increase if you keep the std cams. 290-300deg or such would give a bit more to go with. Then you ofcourse need more CR. What is the piston head height compared to block deck? You should run with 0,8mm gap between piston head and cylinderhead.
My old rallycar 2.0TC had 320deg cams and they were perfectly capable on street. It was a bit harsh under 2000rpm, but right after it it pulled smoothly.
Marko
Pages: 1 [2] 3 Go Up Print
