October 23, 2026, 03:38:38 PM
| | |-+  Advice !
Pages: [1] 2 3 Go Down Print
Author Topic: Advice !  (Read 40159 times)
finnie
« on: March 03, 2014, 10:21:47 PM »
Hi All
Was given a 2 litre engine a couple a weeks ago and was told it had 65K miles on it and looking at it I believe it.
Took head off today to clean it up and it`s very clean ,but noticed that 3 out of 4 pistons "rock" a little bit from side to side ! Surely that means rings are stucked. Now would it not be sensible to put new rings in it now that`s in pieces ?
« Reply #1 on: March 03, 2014, 10:43:15 PM »
The old chestnut again. What do you do? Once you start you usually end up doing a full rebuild.
The other alternative although it's too late now is to change the oil and cam belt, make sure it turns over freely and start it up. If it start, runs well and seems a good runner just use it. If there are problems then you fix them.
The latter is the approach I usually take.....
ZFA16V
« Reply #2 on: March 04, 2014, 10:56:04 AM »
Engines out........
Remove the sump 20min
Remove the pump 5min
undo one big end cap ......pop the piston out 10min......there done.
Check the big end bearings on condition and crank as the others come out.
If bearings are good,you can re-use or slip new ones in.
Do not disturb bearings and remove from rod or cap if you re-use.
Re hone pots and slip new rings on.(check your piston size)to get correct rings.
Don't forget ring gap is ok.
You can do this with leaving front pully on and flywheel.
I think a little rock is fine unless its a race engine.
If i lived nearby,i would do it for you in afew hours,but you have to scrap
the gaskets  Grin
If you do this,you could fit a little washer under releaf valve
spring on pump for that little better pressure(suggest you give to someone that
knows,if you don't).Will not hurt.
Not a full re-build,but a wise thing maybe while out.
Good luck.
« Last Edit: March 05, 2014, 09:57:03 AM by ZFA16V » Logged
« Reply #3 on: March 04, 2014, 01:11:59 PM »
What we did with last couple of engines was
polish crank new bearings, test pump, hone block, new rings, new seals & gaskets,
skim the head reface & grind in valves, set the valve clearences (shims) new ribe head bolts, new water pump & thermostat Wink
finnie
« Reply #4 on: March 04, 2014, 07:35:03 PM »
Thanks guys
Will take out pistons and put in new rings at least . Check the rest  Wink and what also came with engine was a brand new
oil pump NOS fiat stamp and fiat box - would that need the washer trick as well ? The head will go to machine shop for
overhaul because I can  Wink
« Reply #5 on: March 04, 2014, 07:44:10 PM »
Good man Finnie thats a deffo thing to do as every head we did last year had some warpage thats 5 engines lol!
please post up what you are doing pics etc Grin
there were some domed pistons on flea bay last week went for ?141 Cool
ZFA16V
« Reply #6 on: March 05, 2014, 10:02:22 AM »
Won't hurt i think......i did.
Don't forget to to check the aux shaft pump gear splins for wear !!
finnie
« Reply #7 on: March 05, 2014, 05:52:28 PM »
Just had a thought being bored at work  Grin What we did in the 70`s and early 80`s was a lot easier and cheaper  Cheesy
Clean up valves get the paste out and the stick and get rolling Cheesy hot pressure wash the head new stem seals and Bob`s
your uncle LOL
« Reply #8 on: March 05, 2014, 07:42:55 PM »
The machine shop refaces the valves & grinds them in now so no need for that torture Wink
finnie
« Reply #9 on: March 12, 2014, 08:19:11 PM »
Ok all
A few pictures of the 2 litre engine - and other engine is a BMC getting new liners and pistons (for my boat)
[URL=http://s307.photobucket.com/user/finnie2007/media/engines003.jpg.html]
finnie
« Reply #10 on: March 27, 2014, 03:37:20 PM »
Hi All
Just taken the flywheel off to send it away for skimming and found out that bearing for gearbox shaft is not working !
A quick measure says OD 35mm ID 14.7mm width 14mm is that correct ? shaft on gearbox is ID 15mm
Anybody got the correct size ?
« Reply #11 on: March 27, 2014, 09:56:29 PM »
Do you mean the bearing at the back of the crank where the gearbox shaft end goes into?
finnie
« Reply #12 on: March 27, 2014, 10:28:02 PM »
Yes that's the one
« Reply #13 on: March 28, 2014, 06:34:04 AM »
Try a forum search, someone asked the same question a few months back.
finnie
« Reply #14 on: March 28, 2014, 09:15:47 AM »
Thanks Tas -found it  Wink
Pages: [1] 2 3 Go Up Print
