October 21, 2026, 04:52:50 AM
| | |-+  [W] Plug-axis
Author Topic: [W] Plug-axis  (Read 6584 times)
shopper
« on: March 31, 2015, 06:20:22 AM »
hi
i have a big problem
i need a plug-axis with 26mm gearing
all axis that i found are not for drum-brakes
the rear-axle is from the ex-ddr like new and not over 50000km running
so can it be that the axle is from a diesel..?
please quick... my 131 is on a workstation this week.... its not my...just for rent
thanks andreas
shopper
« Reply #1 on: April 01, 2015, 04:22:42 PM »
its good to be a metallworker
done..thx
« Reply #2 on: April 03, 2015, 09:32:40 AM »
I am not quite sure what you mean but I think you are after the larger internal diameter diff planet wheels for 131 saloon ?  if so all series 3 131's had these as axle was slightly wider and the diameter of the half shafts were wider and subsequently the spline on these diff wheels were also a wider internal diameter.
