September 13, 2026, 02:23:10 PM
| | |-+  Bitch to start some times
Pages: 1 2 3 [4] Go Down Print
Author Topic: Bitch to start some times  (Read 57220 times)
« Reply #45 on: December 22, 2009, 11:39:17 AM »
 but other have different opinion about the resistor.
No, I think we are in agreement about the resistor. The Bosch coil MUST have it's resistor in place otherwise it will have 12V on its primary winding and eventually burn out. I also said further up in this thread that these electronic units work best with their OE coils but presumably a 'standard' coil will work reasonably well too although will only provide the sort of spark one would get from a 'standard' points system. The main difference in the coils between standard and electronic is in the primary windings incidentally. There's a limit to the amount of current that a set of points can 'sink' without burning out. Coils intended for electronic ignition units have lower impedance primary windings  and will therefore require much higher current which is not a problem for the switching transistor in the electronic control modules.
« Reply #46 on: December 22, 2009, 07:56:03 PM »
Thanks Thotos,
this explains it clearly.
I was not entirely clear of the differences.
« Reply #47 on: December 22, 2009, 10:15:13 PM »
Theo & Miro
Thanks again you two always have an answer and info to back it up. !!
I will follow up when i get time.
« Reply #48 on: December 23, 2009, 08:07:22 PM »
Ok Theo.
Here is my solution to the crankshaft breather pipe and the 6mm pipe of the bottom of the carb made it up today and fitted.
Pages: 1 2 3 [4] Go Up Print
