October 23, 2026, 12:41:28 PM
| | |-+  131 Brake upgrade
Author Topic: 131 Brake upgrade  (Read 26707 times)
mccabe131
« on: November 01, 2007, 07:37:47 PM »
Hi, any one got any ideas on how i could upgrade the front brakes on my 131 racing,  Huh ???would like to fit vented discs,upgrade must be able to fit inside the 131 sport 13inch alloys.  Embarrassed Embarrassed.thanks guys.
Mick McCabe Kilkenny 1979 131 racing, 1980 1993 Fiat tipo sedicivalvole, 1989 1990 fiesta xr2i, 1991 sierra cosworth 4x4,1983 M B 300 GD,
« Reply #1 on: November 01, 2007, 09:02:52 PM »
If you wish to use 15" wheels then the best value for money will be lancia delta-thema calipers with 284mm discs. The other option is using 254mm discs (vented) from honda civic(will fit after slight modification) with calipers. You will need to make some brackets made of at least 4mm steel.
You need to change the master cylinder to 25,4mm to get a firm pedal. Fiat tipo, lancia thema, delta will fit nicely after a bit of modification and you will need to use some silicone to seal the connection between pump and servo.
« Reply #2 on: November 01, 2007, 09:34:50 PM »
I have the 257mm solid discs as fitted to several Fiats and Alfas with Fiat Bravo callipers and carriers. It's a straight forward swap but I don't think the 24mm wide vented version as fitted to Bravo 155 will be a straight fit (but might be?)
When the original Tarox discs had to be replaced as they went very rusty (!!) I fitted a set of cheap discs bought on eBay and they were hopeless! I realised that a couple of weeks before the 3MA while going round the Mercedes Benz test track at Brooklands and of course I had great trouble stopping during the 3MA. In fact the only thing my brakes were good for during the 3MA was producing A LOT of smoke!
Since then I have replaced the discs and pads for a matched set by Mintex and the improvement seems excellent. I haven't used the brakes in Anger yet but they felt very good while driving round the Gaydon test track in September. It was only 3 laps though so just about enough to get the brakes up to temperature.
I think the best upgrade you can do to a 131 is to fit rear discs. My car has front 131 discs fitted to the rear and uses Golf GTI rear callipers and carriers. The carriers need slight modification and some metal needs to be removed from the panhard rod bracket to make room for the calliper to fit.
« Last Edit: November 01, 2007, 09:37:28 PM by Thotos » Logged
« Reply #3 on: November 02, 2007, 02:20:06 AM »
I believe Fiat Uno Turbo discs and calipers are a straight forward swop.
They are fitted to my 131.
BKFIAT
« Reply #4 on: November 02, 2007, 11:25:36 AM »
rear discs and callipers from an 1800gls fiat132 are a straight swap over for the rear of your 131.Might not be easy to locate.
fiat 131 1600,1300 1300S, 2000sp.? 127 1050,1050sport, 1300GT ,903s, x/19 1300,850sport, 132 1800ES,2X132 2000TC,900T CAMPER, 16V 2.0 Coupe,16v Marea,20v Marea, lada 1500cc estate,MINI 1000,Mahindra 4x4 2.1D& 2cvCo.Roscommon,Ireland.
leifa
« Reply #5 on: November 16, 2007, 07:57:06 PM »
I've fitted most of this this kit on my 131 at the front: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=250151206989&sspagename=ADME:B:AAQ:UK:1
At the front I've got 284 mm vented, grooved and drilled Black diamond disk and at the rear the disks from the kit (284 mm. vented disks from Brakeworld) with front calipers from a Rito/Strada 130 TC. Two Girling masters with a bias adjustment  at the pedal and adjustable pressure regulator for the rear brakes. The rims must be 15" The handbrake is hydraulic. I have only done a few hundred kilometers regularity/challenge rally with the brakes and no track or regular rally yet, but the brakes feel OK.
« Last Edit: November 16, 2007, 08:06:50 PM by leifa » Logged
LeifA
Codriver
KRENZER JEAN
« Reply #6 on: December 19, 2007, 11:25:22 AM »
HAD THE SAME PROBLEMS ON 131
 brakes from a tipo 1.8 gt do fit ... you have only to build the left side at the right side, and do the same for the right side.
 the only problem is you cann't use 13' whells any more..
 made that change 2 years ago without any trouble. Sure, It might  be other solutions,  but I  included the financial sight  too.
kosa131
« Reply #7 on: January 02, 2008, 06:28:05 PM »
I used front break from Fiat regata 100s (disc 257mmx12mm). -14 inch tyres   in my first 131 (131 racing walter rohrl '80). In second 131 (special '77)i have 13inch tyres and   front disc from fso polonez  with lucas brake system (251mm) and calipers from fiat cinquecento/seicento/palio.http://img519.imageshack.us/img519/6839/zdjcie011ay7.jpg
 (this is my first post in this forum, and my english not very well).
131v6
« Reply #8 on: January 02, 2008, 09:52:37 PM »
yep they bolt straight on and work under 13" wheels. Very common conversion. Requires only new brake hoses or adapter fitting.
2 Dr 131 3.2, 124 Special 2.0 turbo, 850 Coupe 1.4, 850 Sport Coupe, Coupe 20VT Plus, Grande Punto Sport....and a couple of projects Smiley
Christchurch, New Zealand
bolger
« Reply #9 on: January 03, 2008, 08:12:19 AM »
I use 257 mm ventilated setup from Tipo/Tempra. It's a straight fit, for steel standard 14' wheels a distance plate is necessary (I've used a standard one from Fiat 125p). I also use 20.64 brake pump.
« Reply #10 on: August 08, 2008, 10:16:54 PM »
BKFIAT
 Offline
     Re: 131 Brake upgrade
? Reply #4 on: November 02, 2007, 04:25:36 AM ?
 Report to moderator    Logged
fiat 131 1600,1300 2000sp.  127 1050,1050sport, 1300GT ,903s, x/19 1300,850sport, 128 1300,900T CAMPER, 16V 2.0 Coupe,16v Marea,Co.Roscommon,Ireland.
anyone tried this conversion? i got a couple of rear axles from 132 1800 and i wonder how much work is it?
selem
« Reply #11 on: August 21, 2008, 07:35:30 AM »
I also use brake from regata 100s, just swap it.
fiat 131S
