July 26, 2026, 03:45:31 PM
| | |-+  Power steering parts wanted.
Author Topic: Power steering parts wanted.  (Read 9572 times)
« on: March 21, 2012, 09:58:15 PM »
Does anyone have any series 3 Supermirafiori 2 litre engines lying around that are only suitable for scrap?
I'm looking for a mounting bracket for the pump and a crank pulley.
strada
« Reply #1 on: April 02, 2012, 06:28:55 PM »
hi dave, i think i have a pulley but will have to double check, the problem will be the bracket which is part of the oil filter housing..  this will need to be exchanged for the one off your engine. the next problem then is the gasket......good luck with that one.  chris
« Reply #2 on: April 02, 2012, 07:37:23 PM »
Is the bracket part of the oil filter housing or does it seperate? I'm sure the gasket could be made.
« Reply #3 on: April 02, 2012, 08:07:47 PM »
the bracket and oil filter housing was all one part and it was made from cast iron or cast steel (heavy) and not aluminium as the normal one and the gasket between the engine and housing was the same as aluminium one.
strada
« Reply #4 on: April 03, 2012, 05:47:51 PM »
the engine in question does not actually belong to me  but is destined for a kit/project car so these parts are not required but i will need a proper gasket or a very well made one to refit the exchanged housing back on to it.  the gasket may come off in one piece but as the engine is not mine i can't risk it.
« Reply #5 on: April 03, 2012, 06:50:23 PM »
I don't think I have a housing to swap so thanks for the offer but I'll have to pass on this one.
Thanks anyway Grin
« Reply #6 on: April 05, 2012, 10:28:30 AM »
Ive got the required fitting on my car, same offer as above, if you can send me a replacement ill let you have the one off my car, on condition the replacement fits and is in good condition that is.
« Reply #7 on: April 05, 2012, 10:30:20 AM »
Ive just rebuilt the engine so i would be looking for a gasket as well!
« Reply #8 on: April 05, 2012, 05:18:03 PM »
Try toad , got loads of bits and cheap pm him. Wink
