October 24, 2026, 10:11:23 PM
| | |-+  Rear brakes fix
Author Topic: Rear brakes fix  (Read 7974 times)
jseabolt
« on: April 02, 2012, 09:48:53 AM »
If I set the parking brake on my 131 for a few days then try to reverse, the rear brakes stick.
The other day this happened and I put the car in drive and lurched forward a couple of feet and they broke loose.
I don't think the wheel cylinders are sticking. I think it's in the self adjusting mechanism since the problem only seems to happen after the parking brake is applied. Anyone know what the fix is? Which component in this diagram is suspect?
1981 Trabant 601
2003 Subaru Baja
« Reply #1 on: April 04, 2012, 07:38:50 AM »
Is the cable free, does it fully release when the handbrake is off? There should be some big arse springs between the brake shoes that pull them together, away from the drum, when the handrake is released.
« Reply #2 on: April 04, 2012, 10:37:50 AM »
'big arse springs 'is that a technical term used for springs down under?
« Reply #3 on: April 05, 2012, 04:40:22 PM »
Or leaking brake fluid on to shoes making them stick, or seized up and rusted adjuster ,
 just strip it all  down and check and a may be  siezed cable .
 slaken off hand brake adjuster before removing drum .
