September 16, 2026, 09:49:07 PM
| | |-+  OIL LIGHT
Author Topic: OIL LIGHT  (Read 19337 times)
« Reply #15 on: November 25, 2012, 09:45:28 AM »
Sorry stand corrected on the valve in filter .. pressure release valve it is.. Not one way valve.. Roll Eyes
« Reply #16 on: November 25, 2012, 10:06:01 AM »
By the way Tas131 ,didn't know they lenghtened the oil pump drive gears on the later cars .. really good to know as i have a 130 T/C engine to strip & rebuild before fitting into my 131 & she will now defo be getting that longer drive installed.. Wink...
Never realised that drive gave trouble , had always thought i was seriously unlucky to have such an odd problem..
Of course i had to be about 130 miles from home the day it happened to me..Had to leave the car stranded in a farmers yard for a couple of days that time before i got back to collect her...
124AC
« Reply #17 on: November 26, 2012, 11:07:28 PM »
As suggested by Dave, check the oil pressure with a guage or a different pressure sender as a minimum.  Flickering can be caused when the diaphragm inside the sender unit fails.
A second-hand oil pump is normally worn.  If you need to remove it to check you will normally find the pump gears to be scored and therefore less able to achieve a steady pressure.
I have seen damage to the drive gear.  I think Guy suggests these are changed on any rebuild.  Nice to hear the later ones are modified.
Lastly, I put 20W50 in a Sport engine with 76K miles.  First cold morning under 5C and it wouldn't even crank over!  I think this would have destroyed a worn drive gear.  Nice new semi-synthetic worked well in all conditions.
« Reply #18 on: November 27, 2012, 07:49:46 AM »
You've got other problems then! Every winter mine starts every morning between 0 & 5 deg, first turn of the key.
hammerbeirne
« Reply #19 on: November 28, 2012, 09:43:59 PM »
Changed the oil and filter to a heavier oil and all seems fine now Smiley
N. Dinis
« Reply #20 on: November 28, 2012, 10:30:33 PM »
You should install a oil pressure gauge... It may seems ok because the light is not on but doesn't mean that there are no problems....
hammerbeirne
« Reply #21 on: December 21, 2012, 05:47:12 PM »
It was on again yesterday when it got hot Turns out all it needed was a new oil light switch all is fine now  Wink
