September 12, 2026, 02:16:10 PM
| | |-+  1600 DOHC camshaft.
Author Topic: 1600 DOHC camshaft.  (Read 6949 times)
« on: July 26, 2013, 12:06:46 AM »
Hi I need the camshaft for a head mounted distributor for a 1600 engine. Anyone can help?
I have for a 2ltr engine but its useless for me I think.
Thanks.
bolger
« Reply #1 on: July 26, 2013, 06:51:42 AM »
If the 2l cam can drive the overhead dstributor, give it a try, they were not that different if I remember correctly.
« Reply #2 on: July 26, 2013, 10:40:20 PM »
Yep, if it's got the dizzy gear on it, use it. The difference in lift and duration on stock cams was not significant.
« Reply #3 on: July 27, 2013, 04:13:35 PM »
OK for this then. Anyone have an idea what I can use to close the hole of the distributor in the block?
« Reply #4 on: July 27, 2013, 11:34:59 PM »
Most of the American twincam spiders had cam mounted didtributors, so you could probably track one down here:
http://fiatspider.com/f08/viewforum.php?f=19&sid=e5b8d33817e5e3aac721231c154cb88d
Or Jason Miller sells them.
http://www.millersmule.com/MillersMuleStore/en/dohc-engine/18-fiat-distributor-hole-plug.html
PS. The blanking plug has to be long enough to hold the oil pump drive gear in place, so just covering the hole is not sufficient.
strada
« Reply #5 on: July 28, 2013, 09:25:11 PM »
the correct blanking plate was used on the digiplex equiped stradas, 130 tc & mk2 105tc, i think i have one somewhere.
« Reply #6 on: July 31, 2013, 12:22:06 AM »
Can you see if you still have it please?
