September 14, 2026, 04:33:36 PM
| | |-+  bigger breaks?
Author Topic: bigger breaks?  (Read 19894 times)
Bubu125
« Reply #15 on: November 11, 2013, 10:09:27 PM »
I have fiat cupe turbo front disc and calipers brembo
« Reply #16 on: November 11, 2013, 10:58:32 PM »
is there much of a modification to install the coupe turbo brakes into a 131 ?
cypriot
« Reply #17 on: February 03, 2014, 06:20:13 PM »
This will fit plug and play!
it's from Fiat Palio 1,6l-16V
disc are from Brembo (slotted) on the pic,
but you can use original ventilated , or cross-drilled,
Enzo  Smiley
Hello Enzo,
Have you used palio 257,5mm discs ?
And palio calipers directly fit without modification ?
WR Ltd Edition
Mods:
Gr.4 Tarmac BodyKit
124 Abarth cyl head
High Comp. Pistons
4-1 Header
H?rmann Intake Manifold
Weber 40 IDF Carbs
GC Spec FW
