September 13, 2026, 02:23:16 PM
| | |-+  wiring diagram needed
Author Topic: wiring diagram needed  (Read 11053 times)
« on: February 07, 2014, 08:09:28 PM »
Would anyone on here have info they could post up on the wiring diagram
from a magneti marelli ''electronic ignition / coil pack  to  a  cam mounted distributor on a 131 engine ?
 Huh
the electronic ignition unit has a couple of connections coming off it ..
idahobrava
« Reply #1 on: February 08, 2014, 01:05:59 AM »
That should be an easy one,  I have this setup on my Brava.  It's pretty simple 2 wires coming off the coil that go into the module and 2 wires that come off the bottom of the module go to the ignition trigger in the distributor.  I'll look into my book.  Mike Stinson
« Reply #2 on: February 08, 2014, 09:08:02 AM »
thanks .. this is actually a problem I am trying to sort for a friend of mine who has an escort mk1 with a fiat twin-cam engine in it ..
the engine has a crank shaft sensor on the front & rear of the crank , this is some aftermarket set up.. but the marelli unit has 6 spade connections on it ..
trying to see what the original or standard set up was.. as the auto electrician he had working on re-wiring the complete can can't figure out the wiring on the marelli module
« Reply #3 on: February 10, 2014, 02:18:37 AM »
I think we may be confusing the bosch with the marelli setup.
« Reply #4 on: February 10, 2014, 07:33:04 PM »
Just trying to sort out a mate with some information .. I have never paid any attention to what ignition system the car runs but I have been told marelli , so trying to get some info on it ..
I have a feeling that the marelli system is not originally from a 131 as I don't understand why its running a crank sensor , unless any of the America injected 131's have a crank sensor ?
No idea where the engine originally came from .. Huh
131 Lover
Fiat power No mercy !!!
« Reply #5 on: February 11, 2014, 09:10:31 AM »
Hi!
It can be from an Argenta,if I remember right they have crank sensor and a type of Speedo sensor on the flywheel,that makes up for 2of the connections!
I have a fiat manual somewhere for Argenta,if its not been missing.
Alf
These are my Fiats
2x 131 2-door 1600cl -81
« Reply #6 on: February 11, 2014, 12:18:51 PM »
Thanks that bit of info is much appreciated ..
If u raise a diagram maybe u could pm me .. Thanks Wink
