September 13, 2026, 01:56:57 PM
| | |-+  131 coil over
Author Topic: 131 coil over  (Read 11371 times)
131 Lover
Fiat power No mercy !!!
« on: September 01, 2014, 07:05:29 AM »
Hi!
I just wanted to show my newly made semi coil overs, i took some new struts i had for a diesel and bought a set of springs with screws for Honda Civic!
I kept the springplates incase i want it change it back!
Still need to road test them, but i just wanted to have adjustable height and a bit harder suspension in the front!
Alf
These are my Fiats
2x 131 2-door 1600cl -81
simon abarth
« Reply #1 on: September 01, 2014, 07:53:38 AM »
hi, good idea, well, he must now see the result on the road. I think you have to weigh the car to Commender the good springs?
pascal.
131 Lover
« Reply #2 on: September 01, 2014, 09:48:40 AM »
Hi Simon!
You're right but at the moment with two small children and no extra time I am happy to get anything together....
I just checked that the Civic had almost the same weight as the 131, that's good enough for me, its only going as a road car.
Alf
These are my Fiats
TfP-Motors
999cc tbo
« Reply #3 on: September 12, 2014, 07:56:28 PM »
i have also these similar "coilovers". but springs are too short, so i put both front and rear springs to front.
DIY -You know where problem is
131 Lover
« Reply #4 on: September 13, 2014, 08:57:12 AM »
Hi TFP!
Do you mean it's to stiff?
I made a distance aluminum piece in the bottom of the strut to get the spring higher , I also have a plastic piece in the top who will steer and keep the spring in place.
Alf
These are my Fiats
TfP-Motors
999cc tbo
« Reply #5 on: September 20, 2014, 06:29:41 AM »
Of course it would be stiffer if there is only one spring.
but the reason for the two spring is that I get the car street legal "MOT"
here rules say spring not be left loose when you pick the car up.
height is now this, and is possible put few cm:s lower until sping is loose... and stifness is suitable for me.
