October 24, 2026, 03:09:08 PM
| | |-+  Lights stay on!
Author Topic: Lights stay on!  (Read 7615 times)
« on: March 08, 2016, 10:02:08 PM »
1977 131 1600.
Been out tonight, initially all ok, lights on and dip and main beam working fine.
After a long run on main beam, lights would not dip.
After returning home found out that I can't even switch them off, three way switch has no effect, have had to disconnect the battery.
I'm suspecting a relay stuck! Burnt out!
Any ideas?
Help!
« Reply #1 on: March 08, 2016, 10:58:21 PM »
Yes, relay must be stuck on. Most probably the contacts 'welded' themselves together. The relay is clearly marked on the fusebox cover so check that first. I think the high beam and horn relays are the same so you could use the horn relay in place of the lights relay to test.
« Reply #2 on: March 09, 2016, 06:38:44 PM »
Spot on Theo!
Identified the relevant relay with a bit of switching on off and feeling each one.
Changed it and all back to normal.
Opened the old relay and the contacts were like a set of very old points with one contact about gone!
