October 24, 2026, 05:01:34 PM
| | |-+  suspension bushes
Author Topic: suspension bushes  (Read 11160 times)
tex
« on: June 30, 2008, 08:09:31 AM »
I thought i would renew the bushes on the rear suspension since i have it off the car to refurbish, but was told the following "Rear suspension bushes are silent block they donot wear out and require replacement, provided of course that your car has original 131R arms on it.
They are now old and occasionally have had replacement arms from a 124 or
132 fitted which do have replaceable bushes". What do you recommend i do to 'refresh the suspension', brakes, diff etc now that it is out?
« Reply #1 on: July 21, 2008, 09:05:27 PM »
yes they do ware out and the hole the bolt go threw becomes elongated, mine alwat went at one end
so just swop them round till i could replace them with rubber or nylon
jason
« Reply #2 on: July 23, 2008, 09:50:45 PM »
Yagmar, a forum member, has new replacement arms for what you want.
mick131
« Reply #3 on: July 24, 2008, 04:04:20 PM »
Does anyone know what the Superflex / Powerflex bushes are like for the rear arms ??.
Are they the same as the original bushes or do they come in two parts at each end ??.
Mick Wilson
« Reply #4 on: July 24, 2008, 08:00:12 PM »
Do they do the powerflex bushes for the rear. If memory serves me correctly when I enquired they had a very limited range ie front anti roll bar bushes only.
« Reply #5 on: July 25, 2008, 02:37:41 AM »
Yes they have front anti roll bar bushes 2 x diameters make sure you order the right ones.
The rear arm bushes come in 2 pieces (thas two per fitting,  cone shapped)
They also used to do rear trailing arm bushes and Panhard rod bushes, i have a set of each yet to fit.
I also have a spare? pair of front superflex anti roll bar bushes 19mm if my memory serves me correct, interested?
« Last Edit: July 25, 2008, 02:39:36 AM by parrish » Logged
