December 12, 2025, 09:01:03 PM
| | |-+  wanted
Author Topic: wanted  (Read 13114 times)
alan.acs
« on: December 26, 2008, 08:14:18 PM »
I'm looking for 15" wheels for my 131.
also looking for a 16valve head any condition will do.
chris131
« Reply #1 on: December 27, 2008, 08:15:42 PM »
I have a set of new 15" X 8" Compomotive ML style wheels - never out of the box.
Also have 2 16V cylinder heads.
If you want I can send you some pics of the wheels?
chris
alan.acs
« Reply #2 on: December 28, 2008, 01:16:18 AM »
are the 16 valve heads fiat 131 ?
« Reply #3 on: December 28, 2008, 10:31:57 AM »
Alan,
if your not interested in those wheels maybe i am!
Chris, what offset are they?
sportman
« Reply #4 on: December 28, 2008, 11:01:42 AM »
ARE THE HEADS FROM 131 ABARTH
chris131
« Reply #5 on: December 28, 2008, 09:15:43 PM »
Hi, No the heads are not 131 - just fiat 16V heads.
« Reply #6 on: December 28, 2008, 09:22:21 PM »
from FWD or RWD fiats?
alan.acs
« Reply #7 on: December 29, 2008, 12:57:05 AM »
fiat what ? early or later engines.
separate cam carrier type if so am interested
What is the et of the wheels and what price?
« Last Edit: December 29, 2008, 12:59:11 AM by alan.acs » Logged
chris131
« Reply #8 on: December 29, 2008, 11:50:07 AM »
The heads are the same as what would have been fitted to a tipo 2000 16V, fiat coupe 2000 16V, lancia thema 2000 16V, delta integrale 16V etc.
The wheels I think have an ET of -8. PCD of 4X98mm and centre bore of 58.1mm - so specifically made for Fiat, no wobble bolts needed  Wink I need ?500 for the wheels, they cost me more but I don't think I'm going to use them.
« Reply #9 on: December 29, 2008, 11:52:29 AM »
-therefore they do not fit any fiat with rear wheel drive.
alan.acs
« Reply #10 on: December 29, 2008, 11:54:09 AM »
They do fit just inlet and exhaust are on different sides.
and you need pistons.
« Reply #11 on: December 29, 2008, 12:29:32 PM »
tried that already. i also have some engines from newer fiat/lancia. opens up a world of new problems...
alan.acs
« Reply #12 on: December 29, 2008, 02:00:21 PM »
Did it not work for you and why ? out of curiosity
« Reply #13 on: December 29, 2008, 09:01:09 PM »
i don't claim it can't be done but...
exaust pipes must be on the left side where space is tight because of the steering coloumn (lhd cars) and starter motor (all models)
distributor, which is attached to the inlet cam is in serious conflict with firewall
« Reply #14 on: December 29, 2008, 10:34:15 PM »
I am confused  Undecided What engine bay is that? It's certainly not a 131 ...
