July 27, 2026, 06:53:34 AM
| | |-+  Wide Arch Tarmac Car Problems
Author Topic: Wide Arch Tarmac Car Problems  (Read 11439 times)
131grp4
« on: January 20, 2010, 03:41:44 PM »
I have to say that if I knew then what I know now.........huh, that old chestnut. If your thinking of doing an Abarth replica, go for the narrow arch version, the problem I'm having with not only finding a reasonable priced wheel is the bigger problem of tyres, I'm at the point where I'm considering going back to Stradale and running 8's & 9's, tyres not a problem. So learn from my mistakes and buy a Stradale body kit.............unless anyone wants to buy my wide arch kit that is? Grin But boy, they do look good! Roll Eyes
« Reply #1 on: January 20, 2010, 04:36:24 PM »
Hello,
not build back to Stradale!
make 50mm wheel spacer per Axle in front per side and 50mm or 60mm wheel spacer on rear Axle per side, and you can use the Original Wheels with 195/50 or 205/50 Toyo. (139.-Euro)
http://www.pro-track.de/rennreifen/toyor888/15zoll/index.php
Look Pic's
Enzo Wink
« Last Edit: January 20, 2010, 04:38:10 PM by Fiat 131 Abarth#2 » Logged
« Reply #2 on: January 20, 2010, 04:40:07 PM »
Next Pic's
Enzo Wink
« Reply #3 on: January 20, 2010, 05:34:53 PM »
Rear 17 x 11 Compomotive with 275/40ZR17 No spacers fitted.
Front 215/40ZR16 No spacers fitted.
« Reply #4 on: January 20, 2010, 05:46:08 PM »
Do not put spacers, you can make the wishbones longer for about 70mm(easy job- see pictures)
Then you need to make the sway bar wider by welding a pipe on top of the cut in half roll bar or make compression struts like the ones used in abarth cars.
Tie rods have to be used with extensions or you can simply put lancia thema tie rods which arte longer than fiat 131 for about 50mm, rest fits.
This will make the car to turn much better than using spacers and also you can use 15"x7" wheels and for such wheels you can have plenty of tires.
« Reply #5 on: January 20, 2010, 05:50:27 PM »
modified wishbone
