June 09, 2026, 05:17:56 PM
Pages: 1 ... 3 4 [5] 6 7 ... 9 Go Down Print
Author Topic: 2000 Tc engine doesn't run  (Read 105148 times)
« Reply #60 on: August 31, 2010, 09:51:12 PM »
That's the toothed round thing on the end of the the cam. It's driven by the belt.
« Reply #61 on: August 31, 2010, 09:55:20 PM »
Timing isn't wrong. Tried all positions of distributor. Somewhere between flames from carburetors and from exhaust there should be a point the engine fires. But it just won't!!!!!!!!!!!!!!! I know. I'm a mechanic for 25 years!!!
fiat131sport82
suljo mohamed. now live london engaland.like 131
« Reply #62 on: August 31, 2010, 09:55:43 PM »
OH you mean CAM PULLEY or if adjustable is a VERNIER PULEY? this is how i call it i never hear of adjustable cam rod ! !  Grin
Please write every part thats is NOT STANDARD fiat t cam and we will find foult.
thanks freind we will fix her  Smiley Grin
suljo m
suljo mohamed from bosnia now live london engaland
« Reply #63 on: August 31, 2010, 10:01:25 PM »
Sorry, for my english isn't always that good Smiley Wink
Here we go:
Twin 44 Weber carburetors on 125 inlet manifold.
Lancia cylinder head with bigger valves
Adjustable pulleys! Grin Grin Grin
Inlet cam 131 Racing, outlet 132 with electronic distributor
Standard outletmanifold (yet) standard exhaust (for looks)
fiat131sport82
« Reply #64 on: August 31, 2010, 10:11:47 PM »
Hi everybody,
I have a serious problem even since I am a Fiat mechanic for 25 years and am rebuilding a group 4 car.
I have a 1978 (one of the first) 131 Racing which won't run. The engine simply doesn't start. I already checked timing and compression, changed cilinder-head, double carbs, complete ignition but it won't run. Towed it three blocks and changed ignition-timing several times. Somewhere between big flames coming from the carbs and big bangs from the exhaust there must be a moment that the engine will run, I think. Does anybody have a suggestion? What am I missing here?
This engine has the following: race-cams with adjustable camwheels,
                                                bigger valves which are perfectly timed.
                                                new timing belt, timing ok
                                                new ignition coil, new cables and sparkplugs
                                                new distributor
                                                double 44 carbs which can breath freely
                                                4-2-1 exhaust manifold
HEEEEEEEELP
Thanks,
Mike
you say first race cam and now Inlet cam 131 Racing, outlet 132 with electronic distributor
what cams is fit and is inlet and exhoust right no mix up  Huh
fiat131sport82
« Reply #65 on: August 31, 2010, 10:13:38 PM »
and you say 4,2,1 ex manifold then say cast ?? standard?? which is it freind Huh
suljo m
« Reply #66 on: August 31, 2010, 10:16:50 PM »
You're right. It's a difficult story. Inlet cam is from 131 Sport but not the original. It's modified. Same counts for outlet cam. Trust me on this one. They are both good for about extra 30 bhp together with the lifting of bigger valves. But that's not the problem.
The problem is in the spark, wrong time, not big enough, anything. I don't know.
« Reply #67 on: August 31, 2010, 10:18:28 PM »
At this moment I changed the exhaust manifold back to standard. I'm trying anything to get the engine running. Undecided
fiat131sport82
« Reply #68 on: August 31, 2010, 10:22:10 PM »
ok but we need real informations and set ups to help
actually i tell you the truth, to fix it you need to see it, its crazy try to fix a engine on internet you needs to be with is in real life knows what i mean  Wink speculations never can fix like ill persons need to see doctor no check forum good luck!  Cool
suljo m
« Reply #69 on: September 02, 2010, 07:50:11 PM »
There I was tonight, giving it another go. Exchanged two coils. O yes, coughing from the carburetors and big blasts from the tailpipe... Somewhere in between there should be a firing point. Nothing again.
But I noticed, while trying to start the engine, that the ground cable from the battery gets very hot. So I took a piece of sandpaper and cleared the connection points. Didn't help. Then it got to dark to continue.
« Reply #70 on: September 02, 2010, 08:28:03 PM »
ground the engine directly from the head to battery negative
« Reply #71 on: September 02, 2010, 08:34:15 PM »
From the head? What do you mean?
« Reply #72 on: September 02, 2010, 08:39:39 PM »
take a big fat piece of wire and connect the nearest part of the engine directly to battery. shortest way should be from one of exaust manifold studs.
« Reply #73 on: September 02, 2010, 08:50:32 PM »
What good would that do? Ground cable is fine and it's an original one. And since I cleared the connections again tonight I know it works fine. I'm going to have another look at the starter motor for I think this is the problem of the wire getting hot. I don't think this has anything to do with the engine not firing. Please state if you think otherwise. I'm staying open for suggestions.
Thanks,
Mike
131 Devon Dave
« Reply #74 on: September 02, 2010, 08:53:12 PM »
Are  we sure the actual cam timing or the cam profiles are ok? With all the back firing it may be the cams to piston is not where it needs to be. The cam timing marks may line up but the lobes may be opening the valves in the wrong place
Pages: 1 ... 3 4 [5] 6 7 ... 9 Go Up Print
