October 23, 2026, 06:28:41 PM
| | |-+  Remove wheel elecronics
Author Topic: Remove wheel elecronics  (Read 16210 times)
anderhil
« on: August 27, 2011, 06:56:21 PM »
Hi guys!
Can anyone help me how to remove wheel electronics from wheel?I mean how to disassemble it. I can't find similar topic, thanks.
« Reply #1 on: August 27, 2011, 07:01:56 PM »
What do you mean by wheel electronics? The only thing I can think of is the pad wear sensors?
anderhil
« Reply #2 on: August 27, 2011, 07:06:22 PM »
I mean steering wheel that there is an electronics on the wheel:
indicator/wiper stalks and other.
I want to take it out from the wheel, how i can disassemble the steering wheel?
« Reply #3 on: August 27, 2011, 07:17:35 PM »
Ahh, I see. Remove steering wheel centre and undo big nut (24mm I think).
Remove steering wheel.
Remove column shroud by undoing screws from underneath.
Disconnect wires by pulling apart multi-plugs.
Undo the clamp screw then remove the switches by pulling them off the column towards you.
anderhil
« Reply #4 on: August 27, 2011, 07:22:05 PM »
I have a problem with removing the steering wheel, I have undone the big nut, and I can't remove the wheel - it's stuck. trying to rotate it, pull-nothing happens. What should I do?Pull or rotate?
« Reply #5 on: August 27, 2011, 08:05:36 PM »
Try spraying some releasing fluid on and leaving it overnight. If it is really tight you might need a puller on it.
« Reply #6 on: August 27, 2011, 10:54:34 PM »
i have removed a stuck steering wheel by running the nut back on by hand & then placing the correct sized socket
over the nut and hitting it a few times with a hammer, the shock vibration sometimes loosen's the wheel ,
if not use a pullers as suggested by mirafioriman
« Reply #7 on: August 27, 2011, 10:57:39 PM »
Once you have left it over night with the releasing fluid,
Put the nut back on the just enough to bring the thread to the top
Set the seat back just a bit further than you sit with your arms outstretched.
Put your feet on the bulkhead behind the pedals
Grab the wheel with straight arms.
Push as hard as you can with your feet and at the same time heave your arms back and fourth with your shoulders, not your arm muscles, keep you arms straight.
This will make the wheel flex and come off
Now you'l see why we put the nut back
It stops you getting hit in the face with the wheel.
If this doesn't work get bigger muscles  Grin Wink
  Works for me
       Roger..........
N. Dinis
« Reply #8 on: August 27, 2011, 11:03:55 PM »
Maybe you'll need to hit in side of the sterring wheel once or twice to make it get loose..
jseabolt
« Reply #9 on: September 30, 2011, 05:09:13 AM »
I didn't see this mentioned. Instead of pulling forward on the wheel, try pulling on the wheel at the 9 o'clock position while pushing in at the 3 o'clock position then reverse. Do this about 3 or 4 times and the wheel will pop right off. I would advise leaving the nut on just enough so the wheel doesn't fly back and hit you in the face.
1981 Trabant 601
2003 Subaru Baja
« Reply #10 on: September 30, 2011, 07:20:20 PM »
Just like I said with a little less detail Tongue Roll Eyes
jseabolt
« Reply #11 on: October 02, 2011, 10:57:25 PM »
I keep hearing this crunching/rubbing sound as I turn the wheel. Didn't seem to hear it with the original steering wheel. I'm using a 124 Spider hub adapter and fake MOMO steering wheel I found off Ebay.
I decided to pull the steering wheel and hub adapter once again to see where the noise is coming from. Still can't figure it out. The horn tabs are well greased which has caused a scraping sound in the past on my 124 Spider.
So I took a how-to video while was at it. The first attempt failed because the nut wasn't loose enough. So I loosened the nut several more turns. Pops right off.
http://s222.photobucket.com/albums/dd148/turbofiat/Brava/?action=view&current=Steeringwheelremoval.mp4
1981 Trabant 601
2003 Subaru Baja
