August 29, 2026, 05:41:59 PM
| | |-+  dashboard/dials light
Author Topic: dashboard/dials light  (Read 6169 times)
pinkfloyd
« on: November 24, 2011, 02:28:53 PM »
Help needed again Smiley
well can someone suggest how i put put more light to my instrument panel
ie the 3 small boxes on my dashboard. shall i put LEDs instead of normal lamps?
regards
ian
« Reply #1 on: November 24, 2011, 06:41:31 PM »
Is the dimmer working properly? Also try replacing the standard bulbs with new standard ones, they can dim with age.
pinkfloyd
« Reply #2 on: November 24, 2011, 07:04:23 PM »
ehhh thats a good question but i dont think the series 3 had a dimmer!!!
« Reply #3 on: November 24, 2011, 07:11:43 PM »
I could be wrong but I think it does. You twist one of the knobs on the instrument cluster Wink
« Reply #4 on: November 24, 2011, 07:15:07 PM »
Just double checked, it does indeed. It's the right hand one of the three.
« Reply #5 on: November 25, 2011, 01:54:39 AM »
I recently had issues with the dimmer on my car, the plastic arm for the wiper on the rheostat broke. I replaced the dimmer from another instrument cluster, but it worked intermittently. So I simply soldered a wire across the rear contacts, full brightness now. I've been contemplating fitting red Led's, just for something different.
