August 25, 2026, 12:27:32 PM
| | |-+  Bushings...
Author Topic: Bushings...  (Read 18224 times)
« on: October 15, 2012, 09:35:12 PM »
I've been looking around for these without success....They are for the anti-roll bar (at the rear). The pictures show 2 of the ones removed from the car....The thickness is 15mm and the outside diameter is 38mm. Inside diameter seems to be 18mm. I need 4 in total.
Can anyone suggest a supplier please?
« Last Edit: October 15, 2012, 09:45:18 PM by kev131 » Logged
« Reply #1 on: October 15, 2012, 10:26:51 PM »
Rear anti roll bar? The 131 doesn't have one?
« Reply #2 on: October 15, 2012, 10:55:10 PM »
No it doesn't! Unless someone has fitted one (I've seen two 131s with rear anti roll bar). Some Ladas had rear anti roll bars that can be adapted to fit a 131. Probably Kevin means trailing arm bushes? But they are a single piece rubber for the 131 while Kevin's photo shows what looks like trailing arm bushes for a 124. If that's the case then Yagmur can probably supply them. Or maybe Kevin means the front anti roll bar? Yagmur's front anti roll bar bushes look very similar to the photo posted by Kevin
« Reply #3 on: October 16, 2012, 07:21:18 AM »
Apologies for the confusing phraseology - It's the anti-roll bar at the front of the car but I wanted to differentiate between the bushings nearest the bumper (not required) from the ones where the roll bar meets up near the track control arm.
These are the actual ones removed from my car and there are two at each side of the car. My mechanic has looked at what Yagmur has shown on his website but doesn't think they are the same.
Maybe Yagmur can tell me...? Smiley
Any other suggestions welcome too as the suspension is currently dismantled and I need the parts quickly. Thanks...
« Reply #4 on: October 16, 2012, 12:24:07 PM »
Which one of you cars are they off Kev?
Mark at IRS replaced all of the bushes on my Abarth a few years ago but the set up is different on the Abarth to production cars. Not sure that they are all the same across the production range either Undecided, but I have a feeling that some fitted to my 131s in the past were actually slightly modified Ford Escort bushes Shocked Shocked
« Reply #5 on: October 16, 2012, 12:48:04 PM »
Thanks for the interest Si - My Series 3 Supermirafiori..... Wink
They seem similar to the Sport set up....if that helps ?
« Reply #6 on: October 16, 2012, 01:02:35 PM »
This might help. May have to re use the steel insert.
http://www.ebay.co.uk/itm/New-Fiat-127-128-NOT-COUPE-131-RUBBER-BUSH-FOR-FRONT-SWAY-ROLL-BAR-TO-ARM-/300619837521?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item45fe56b051
« Reply #7 on: October 16, 2012, 01:22:15 PM »
Thanks Bobby - I bought 4 of these but they are smaller (external measurement) and thicker.  Huh
Any other ideas?
« Reply #8 on: October 16, 2012, 01:28:36 PM »
Might be worth sending measurements here too.
http://www.superflex.co.uk/categories.php?cat=73
Also- http://www.ebay.co.uk/sch/i.html?_sacat=0&_from=R40&_nkw=rubber+bushes&_nkwusc=rbber+bushes&_rdc=1
« Reply #9 on: October 16, 2012, 06:08:56 PM »
saw the superflex bush man at coombe ,said he now does all 131 bushes ''' Grin
« Reply #10 on: October 16, 2012, 06:12:34 PM »
Kevin, I strongly advise to replace all bushings - it's not a cost issue, the bushings cost next to nothing, and the job will be properly done  Smiley
« Reply #11 on: October 16, 2012, 06:41:59 PM »
If so that's great news  Cheesy Hope they make 130 and 132/Argenta ones at some point Wink
haggler
« Reply #12 on: October 21, 2012, 03:09:13 PM »
Hi i used the bushes from e bay on my 82 sport they fitted fine. The old ones only look different and the mesurments are different due to years of being compressed and wear and tear.
« Last Edit: October 21, 2012, 07:50:11 PM by kev131 » Logged
« Reply #13 on: October 21, 2012, 04:16:32 PM »
Kev,
Yagmurs fit a treat, they are slightly different but far superior to the originals, you might need two of the metal tubes as these act as distance pieces, they tend to wear/corrode over time, i had an extra pair made up when i did my anti roll bar bushes, two different diameters of anti roll bear were fitted during the 131 production history.
if you need the metal tubes let me know and you can have them for the cost of postage from Spain.
PS: I also have surppless to requirements 4 very reasonable original's as shown in your photos.
« Last Edit: October 21, 2012, 06:35:38 PM by parrish » Logged
« Reply #14 on: October 21, 2012, 07:51:18 PM »
That's interesting - Thanks - I will consdier that.  Smiley
