July 27, 2026, 04:52:22 AM
| | |-+  new round head light s
Author Topic: new round head light s  (Read 6687 times)
« on: May 27, 2013, 07:24:08 PM »
i take it some of you needed  these , but seal beams ,, but cheap for 4 Shocked
http://www.ebay.de/itm/CERAMIC-H4-HEADLIGHT-RELAY-WIRING-HARNESS-HEADLAMP-LIGHT-BULB-SOCKET-PLUGS-5-3-4-/330795136119?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AFiat|Model%3A131&hash=item4d04ed3477
http://www.ebay.de/itm/5-3-4-HALOGEN-HEADLIGHT-DIAMOND-CRYSTAL-HEADLAMP-CLEAR-60-55W-H4-LIGHT-BULB-PAIR-/330826064221?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AFiat|Model%3A131&hash=item4d06c5215d
« Last Edit: May 27, 2013, 07:49:33 PM by jasonh131 » Logged
paul raceing
« Reply #1 on: May 28, 2013, 09:27:38 PM »
hi would they fit my fiat 131 raceing 1981 thanks
« Reply #2 on: May 28, 2013, 10:06:57 PM »
these are probably for left-hand drive cars & there doesn't seem
to be any mounting lugs on the rear of the lamps going by the side picture provided in the add.. also if you were going to use on a 131 racing/sport the  lamp would have a different shaped glass to the original fiat units..
longhamrob
« Reply #3 on: May 29, 2013, 07:36:38 AM »
I have ordered one of those wiring looms. The connection to the main beams will need modifying but they are hidden under the rubber covers.
A very good idea that fitted correctly will look like 'standard'.
All 131 owners will be very surprised at the voltage drop just when on low beam. Expect 1 volt + to have disappeared.
I rewired just this circuit on another 131 similar to this kit and the lights are now superb.
« Reply #4 on: May 29, 2013, 05:28:39 PM »
I have heard those wiring kits are quite good ..
