July 29, 2026, 12:04:44 AM
| | |-+  left or right thread
Author Topic: left or right thread  (Read 9909 times)
finnie
« on: February 26, 2014, 08:29:58 PM »
Hi All
Need to take off my crank pulley to change timing belt on my 2 litre engine but can`t remember if it`s left or right hand thread ?
« Reply #1 on: February 26, 2014, 08:59:35 PM »
Taken from Hynes manual . Smiley
finnie
« Reply #2 on: February 26, 2014, 09:38:04 PM »
Thank you  Wink
« Reply #3 on: February 26, 2014, 11:06:17 PM »
We've had this dissuasion before , just slide it behind the pulley, I've never needed to take apully  off . there a nightmare Huh
« Reply #4 on: February 26, 2014, 11:33:02 PM »
I have seen bottom crank gear wear on a 2 litre engine and the only way to check properly is to remove the crank pulley. They do wear so make sure you check. Crank gear had cut the belt causing it to fail and bend valves Sad
« Reply #5 on: February 27, 2014, 02:08:50 PM »
I've never managed to get a belt under the crank pulley  Undecided  I always take the pulley off.
finnie
« Reply #6 on: February 27, 2014, 02:13:51 PM »
I`m taken it off for belt change and a good clean behind  Wink
« Reply #7 on: February 27, 2014, 04:56:11 PM »
I tried it once on My Sport as a last minute job before Scotland 3ma trip and you have to twist the belt and feed it in. Standard belts can be done but I doubt the 1" wide will fit without damage.
donk r8
Chris Paull
« Reply #8 on: February 27, 2014, 09:42:32 PM »
 easy to take the pulley off if you lock the flywheel, strip of steel, two holes one bolt in gearbox housing and one in flywheel.................... Roll Eyes
 And yes I had to check the manual as I couldn't remember if it was a left or right handed......... Grin
1600 Supermirafiori    Fiat Barchetta  Fiat Ducato 2.8 Motorhome    Rover SD1 4.0 V8
