August 27, 2026, 02:24:21 PM
| | |-+  Anti freeze advice
Author Topic: Anti freeze advice  (Read 7024 times)
Crazypierre
« on: August 27, 2018, 09:09:51 PM »
Evening Gents,
Hope you're all well.
I decided to flush out my old coolant and wonder what sort of antifreeze I should use.
Mine is a 1979 131 1300 CL pushrod engine.
I see some are blue, some red.
My Haynes Manual says Glycol based......
I'm going to need just under 2 litres for a 25% mixture.
Thanks for any advice you can give.
Pete
« Reply #1 on: August 27, 2018, 10:42:31 PM »
I would stick with the good old-fashioned Glycol based Blue stuff and change it every two years.
« Reply #2 on: September 02, 2018, 01:10:27 PM »
Remember that anti freeze temp should be calculated with moving airflow chill and not just static air temp.   Rad gets colder as you drive in ice cold temps.
Use a 50% mix.
