October 22, 2026, 11:47:58 AM
| | |-+  back up light switch
Author Topic: back up light switch  (Read 15130 times)
Henk
« on: February 03, 2020, 02:54:42 PM »
Question
Have no back up light function, no signal to the rear bulbs
I suspect it is the switch....
Is it easy to replace? and where do I find it? anywhere on the gearbox I guess Huh
Henk
Fiat Mirafiori 1.6 A1.00
MB W114 280 C
Honda CB750 1972
BMW E30 318 Touring
Mini 2006 Cooper S
« Reply #1 on: February 03, 2020, 05:13:52 PM »
It's at the back of the gearbox but check the connections first. With time the connections get weak and sometimes even drop off the switch.
« Reply #2 on: February 04, 2020, 08:45:07 AM »
Question
easy to replace and the same part as fiat dino and others. Very common to find. But, check this out: I had the same problem and it turned out that the issue was that the the wire runs near the escape line under the right front seat. Follow the wire and you may find that it's burned near the escape line.
Henk
« Reply #3 on: February 04, 2020, 05:35:26 PM »
thanks a lot guys
will check both suggestions.
I think it is not a MOT issue here in the Netherlands as the car is before 1997  Grin
(MOT next week.... Undecided)
Henk
MB W114 280 C
Honda CB750 1972
BMW E30 318 Touring
Mini 2006 Cooper S
« Reply #4 on: February 22, 2020, 09:06:48 AM »
si I presume you left the car as is before MOT....
Henk
« Reply #5 on: February 29, 2020, 09:48:21 AM »
yep, got the new MOT (valid for 2 years) without the back up lights working
Henk
MB W114 280 C
Honda CB750 1972
BMW E30 318 Touring
Mini 2006 Cooper S
Crazypierre
« Reply #6 on: March 20, 2020, 01:45:42 PM »
Hi,
I had a similar problem where both the brake lights wouldn't come on.  It turned out to be the connectors to the rear of one of the right hand side light cluster which had come loose.
Because the left side light cluster is "fed" off the right side light cluster, when the right cluster connection got loose, it didn't operate the left either.
PC
« Reply #7 on: March 24, 2020, 05:06:41 PM »
in my car the left side cluster feeds the right side instead.
