June 10, 2026, 06:22:57 PM
| | |-+  fram Oil filter
Author Topic: fram Oil filter  (Read 24995 times)
« on: September 24, 2009, 02:27:36 PM »
These FRAM Oil Filters are for sale on ebay for 131 etc, don't touch them with a barge pole, years ago I always wondered why a sport I then owned would rumble down the crank on first starting if not driven for a couple of days or more and I knew the shells were fine as I had not long rebuilt it, the problem turned out to be the FRAM Oil filter I was using as there was no non return valve fitted in it so the oil would drain back out of the crank. Used FIAT Oil filters & MANN Oil filters after and had no more problems.
« Last Edit: September 24, 2009, 02:33:30 PM by david » Logged
« Reply #1 on: September 24, 2009, 02:35:45 PM »
But the filter sits vertical "hole side up" in a 131 engine so the oil cannot drain out of it. Strangely, I have this rattle problem with my Trevi since I replaced the oil and filter with a Champion C102.  Undecided
« Reply #2 on: September 24, 2009, 02:42:23 PM »
well if you take it off & compare it with an original Fiat filter or a MANN filter you will see the non return valve in either of those and not in the fram one, its in the centre, don't know about champion filter as never used it but sounds the same problem but using one with non return valve one cured the problem with my car instantly.
« Reply #3 on: September 24, 2009, 03:20:33 PM »
Agree with you 100% David use a genuine filter as they are made for the car as is a saving of a pound worth ruining an engine and it looks terrible looking in at an engine bay and finding spurious parts every where as it shows a lack of love for the car...
« Reply #4 on: September 24, 2009, 06:32:42 PM »
Well said Dave, toyota had the same problem with the spurious oil filters not having the non-return valve & many a celica timing chain suffered because of, so genuine only for my babies!!
« Reply #5 on: April 03, 2010, 09:31:52 AM »
which later fiat models use the same one and does the alfa nord  twin spark engine use it as well Undecided
« Reply #6 on: April 03, 2010, 09:54:16 AM »
Note to self:
Check oil filter when next home> Grin
« Reply #7 on: April 03, 2010, 09:42:03 PM »
I can also recommend PUROLATOR filters !
« Reply #8 on: April 09, 2010, 09:14:03 PM »
I got a k/n oil filter
 http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=390145948005&ssPageName=STRK:MEWNX:IT
 expensive  but cheaper than a fiat one ,special order ?15 Huh
« Reply #9 on: April 09, 2010, 09:27:11 PM »
Interesting didn't know that K&N did oil filters. This business with the non return valve? Seems not all the K&N filters have them, it says 'where applicable'. Does this stop the oil draining into the filter or out of it?
« Reply #10 on: April 09, 2010, 09:43:52 PM »
It must hold a certain amount of oil in the crank as without it they will rumble down the crank on start up, if you dont want to pay for a fiat fiter buy a mann filter.
« Last Edit: April 09, 2010, 09:47:08 PM by david » Logged
« Reply #11 on: April 09, 2010, 09:46:27 PM »
It must stop oil draining into the filter then as as Theo says it can't get back out due to gravity.
« Reply #12 on: April 09, 2010, 09:50:57 PM »
Ive looked at these k&n oil filters but does it not say the ones they are selling are for the 1800cc engine ?
« Reply #13 on: April 09, 2010, 10:01:34 PM »
I think the 1600, 1800 and 2000cc engines all use the same filter.
« Reply #14 on: April 09, 2010, 10:12:16 PM »
Just sent a message to the seller of these k&N oil filters and asked if they are fitted with a non return valve and if the answer comes back NO then they arent any good.
